RETROFIT TO R-143
In retrofitting a 1968 GTO using A-6 compressor,has anyone experience any leaking problems from clamp type fittings. Drier,o-rings,and POA valve will be upgraded. Of course I meant R-134
I would avoid hose clamps. Most NAPAs will make hose assemblies. If you're not worried about originality I would change the compressor to R4 instead of A6. Then change to accumulator and eliminate expansion valve and or POA. It's a really easy conversion. But that's just me.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Customer does want to keep original look.
Then NAPA assembly...Most times you can use original fittings...
You really need to change the hoses to the new type with a liner. The old ones are porous.
