Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 03-15-2020, 11:40 AM
Adecco Adecco is offline
Default 71 400 .30 over
Nice built Pontiac 400 (71 block) with 65 -2+2 heads (76) making the compression 10-1 ratio, bored .30 over, Comp cams roller rockers, hei distributor, dbl roller timing chain, pick up tube on oil pump welded, Melon Oil Pump, stock rods, ARP bolts, cam specs are a Lunati Bracket Master 2.. 290 intake /290 exhaust 490 lift. stock fuel pump..this is a long block you have to do a final adjustment on the rockers, install a intake and carb. . $2500 no trades..
ID:	534498   Click image for larger version
ID:	534499   Click image for larger version
ID:	534500   Click image for larger version
Old 03-15-2020, 12:21 PM
FYI .. I upgraded the heads from pressed in rocker arm studs to BBC screw in ..
Old 03-16-2020, 09:16 AM
thebuick thebuick is offline
nice deal, I have the intake and Carb for that year if interested,If I had a car to put that in I would snatch it up. glws
Old 03-17-2020, 02:48 PM
Default Update pics
Robin egg blue
ID:	534649   Click image for larger version
ID:	534650   Click image for larger version
Old 03-20-2020, 11:35 AM
pontiac rodder's Avatar
pontiac rodder pontiac rodder is offline
GLWS
Old 03-20-2020, 06:09 PM
Thanks...
