Look for input and pics of what members have done with 61-63 Tempest/LeMans front ends. Aftermarket looks to be nonexistent. Would be a limited street/ grudge car. Aiming for mid 9’s.
Thank you |
On my car the front suspension is basically stock. I have coil over shocks, and Wilwood disc brakes. The steering box, pitman arm, center link, and tie rod ends are all factory stuff. It's a track only car though.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
CHE Performance Girard, PA installed this for me. Awesome rack and pinion and custom A arms. We were able to put 7 degrees of caster in it. Here's the link to the build.
https://r.tapatalk.com/shareLink/top...ink_source=app Sent from my moto z3 using Tapatalk
________________________________ Paul Tavana Tribute Car https://www.hotrod.com/articles/hppp...tting-it-done/ 10.40@126 mph all motor |
Ernie Kepplers 63 White Warrior(Dave Johnson’s old car) runs the same suspension as Gary.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
What type of rear suspension did you use? Did they do it also,? Thanks.
