Old 03-24-2020, 12:58 AM
beastlykirby beastlykirby is offline
Default Broken a-arm
So broke the A-arm never seen it break here before. Its not even in the ball joint its about 1 inch from the ball socket. Only doing about 2 mph so no major damage..
ID:	535221   Click image for larger version
ID:	535222   Click image for larger version
ID:	535223   Click image for larger version
Old 03-24-2020, 01:13 AM
Stuart's Avatar
Stuart Stuart is offline
It looks like the right side of the break in the last picture has rust on it, which would indicate it's been cracked for some time before it came apart altogether. Good thing it happened at low speed.
Old 03-24-2020, 01:50 AM
Yeah, it looks like it was previously damaged and then broke from the stress when i fully turned the wheel and started backing up into the garage. Fortunately no damage was caused other then the brake line and the a arm.
Old 03-24-2020, 02:33 AM
Yeah, looks like only an inch or two is newly exposed metal. Good thing it was at low speed is right.
Old 03-24-2020, 02:50 AM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
I like the colour of your car, looks really nice. I guess you have an excuse to buy some tubular a-arms now..
1968 - Pontiac GTO
Old 03-24-2020, 06:56 AM
coonhunter70 coonhunter70 is offline
I wonder if it had been heated there before to remove the ball joint.
Old 03-24-2020, 07:51 AM
dataway's Avatar
dataway dataway is offline
Exactly what I was thinking ... that would be right at the edge of the HAZ (heat affected zone) if it had been heated with a torch.
Old 03-24-2020, 08:06 AM
thepontiacman's Avatar
Wow, I've never seen that before. Most times problem is ball joint or tie rods that fail.
Glad it was very low speed and you and your car are ok.
Sent from my XT1650 using Tapatalk
Old 03-24-2020, 08:53 AM
Very rare occurrence, but have seen this before. The much more common problem with near 50 year old used lower control arms are the ones from northern drivers & from fieldcars, ones that sat on the ground for decades & moisture attacked the lower controls arm, usually pocking the metal & thinning the flat area where the shock mtg clips slide on.
25 years ago, hauling in cheap A-body partscars, I'd disassemble each chassis & mark & sort the lower control arms. The absolute worst condition were pitched, the best saved for future restorations. Lowers that were pitted up some, maybe pocked a little, but usable went with cutoff frames, A-body PS pitman arms, & Pinto spindles to IMCA dirt track chassis builders. The IMCA chassis guys had the Pinto/MustangII spindles made in China, then they followed up with A-body stamped steel lower control arms. These "repop" lower control arms then took off. They are fairly easy to spot, the leading edge of the control arm where it rolls over out by the ballpoint is not as deep on the Chinese lower control arms versus originals.
Old 03-24-2020, 09:05 AM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
Looks like it's time for a complete front suspension rebuild. Those ball joints aren't looking to good either.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 03-24-2020, 09:34 AM
Dennis H.'s Avatar
Dennis H. Dennis H. is offline
By looking at the newer sway bar links, surprised it didn't get caught when they were installed, they mount real close to where the break is, and that crack appears to have been there awhile.
Old 03-24-2020, 10:21 AM
Anthony Anthony is offline
I have a set of original ones off my 68 you can have them if you want. I went with global west stuff in my car.
Ant
mgarblik mgarblik is offline
Very pretty car and glad no outer body damage. That is not a common failure area, but 2/3 of the area was cracked long ago it seems from the rust line. Your car looks stock so I personally see no reason for an aftermarket front suspension, unless you just want to go that way. I would replace the broken parts, scrape and clean the other parts for careful inspection and get back to enjoying the car. It's very unlikely you would have a repeat failure.
