Old 03-29-2020, 03:59 PM
jonathonar89 jonathonar89 is offline
Default Log Manifold Modification Question
Got an oddball question here. I just bought a 80-81 NA 301 manifold to try and do an EFI install on my ‘79 400.
Has anyone ever tried milling off the ball/socket to convert to a flat gasket on a log manifold? I’m figuring I can do this so that I can open up the diameter of the inlet/outlet to run a slightly larger crossover and down pipe (hopefully 2.5 crossover and downpipe).
Also, any recommendations to filling in the center hole which is not needed for the earlier style d-port head? Tap it and mill a bolt flat on the back side? What could I use for a filler material if that’s possible?
ID:	535688   Click image for larger version
Old 03-29-2020, 04:41 PM
242177P's Avatar
242177P 242177P is offline
Get an earlier manifold, and simply weld a sensor bung into your headpipe instead.
Old 04-04-2020, 03:32 PM
My car is in project mode. I'm going to try and make this work. I'm going for a factory appearing install and low cost. Performance is a thought but not as much of a priority.
Untitled by Jonathon Randolph, on Flickr
Old 04-04-2020, 05:02 PM
Schurkey Schurkey is offline
Why bother to spend all the extra money for fuel injection if performance is an afterthought? A properly set-up carb will give you everything that FI gives you, and potentially better fuel economy as a bonus.
The Following User Says Thank You to Schurkey For This Useful Post:
Old 04-04-2020, 06:49 PM
I have nothing against carburetors. Just doing a fun and different project using factory GM parts and aftermarket computer. The TBI I have is a Rochester (same people who made the quadrajet).
454 TBI was $30-$40.....o2 301 manifold $75....Innovate Motorsports wideband $120...Megasquirt 2 efi computer $210...harness $65...’81 301 Pontiac computer distributor $80.
By going used or 2nd-hand-new, I don’t have too much money in it. I’m also working with my engine that was stolen. All the stuff purchased was missing after I got it back.
Old 04-04-2020, 07:06 PM
I think you’re going to have difficulty sealing a flat gasket, the factory went to the tapered seal with no gasket in 1964 probably for that reason.
I’d open them up to accept a 2-1/4” pipe and forget the flat gasket.
Old 04-04-2020, 07:55 PM
You may be right. I went out to the garage just now. Looks like the crossover opening is right about 1.7" and the outlet about 1.9". Both have a flat portion that can open up about .25". Without cutting into the ball portion, it basically can be opened up to a 2" crossover and 2.5" outlet for the downpipe.
Crossover inside diameter....
Outlet inside diameter....
Outlet diameter of flat portion...
