Old 04-08-2020, 04:52 AM
dataway's Avatar
dataway dataway is offline
Default oil pressure gauge line ferrules
Does anyone know a source for the 1/8" compression gauge line ferrules used in oil pressure gauge line kits?
Getting tired of buying new kits just so I can change length, re-route etc. Occasionally I can get them off the plastic line and use them one more time, not so much on copper.
Would also come in handy for making my own lines for various other shop related gauges.
Old 04-08-2020, 06:44 AM
pontiacmark's Avatar
pontiacmark pontiacmark is offline
Would this work?
https://ph.parker.com/us/en/brass-co...fittings/60c-2
1970 GTO 400 Atoll Blue, PS, PDB, A/C
Was M20 4 speed, now has Keisler RS600 5 speed.
The Following User Says Thank You to pontiacmark For This Useful Post:
Old 04-08-2020, 08:04 AM
Hardware stores here have compression fittings and parts.
Clay
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post:
Old 04-08-2020, 12:51 PM
dataway's Avatar
Mark, I've seen the barrel shaped ferrules but I'm not sure if they would work with the existing fittings on oil pressure lines which use a funnel shaped ferrule. Be nice if they did, I've found those at about $6 for 50 of them
Quick, I'm trying to avoid the whole fittings, just need the ferrule. Most of the hardware store compression fittings aren't compatible with the oil pressure line fittings.
Old 04-09-2020, 04:36 AM
Redpiston Redpiston is offline
Try demon-tweeks.com Search for Goodrich replacement olive
Old 04-09-2020, 05:30 AM
dataway's Avatar
Very similar, but appears to be in metric sizes ... or maybe -AN sizes.
Old 04-09-2020, 08:01 AM
chrisp chrisp is offline
https://www.ebay.com/itm/12-pieces-B...e/273431077552
Old 04-09-2020, 11:30 AM
65gto69's Avatar
65gto69 65gto69 is offline
I got tired of changing them out all the time and leaks so I went with the braided oil pressure line. It screws on at both ends, just have to get adapters to go from origin size to line size. Never have to deal with another ferrule again.
https://www.jegs.com/i/JEGS/555/4105...SABEgJBHPD_BwE
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
The Following User Says Thank You to 65gto69 For This Useful Post:
Old 04-09-2020, 11:37 AM
dataway's Avatar
That might be the solution for me right there. I'm far less likely to damage, kink or burn that line.
Old 04-09-2020, 01:31 PM
Chris65LeMans's Avatar
There's a fitting supply store near my old house - that's where I got my stuff when I re-plumbed my oil pressure line in copper. I seem to remember buying most of the stuff from Summit, then going to that supply store for the last little pieces that I needed.
Back then, I didn't know what I didn't know. If you know what you're looking for, you should be able to track some down from a similar fitting supply place.
Old 04-09-2020, 02:59 PM
76TA462 76TA462 is offline
I replaced my ferrule from Napa.
Old 04-09-2020, 07:12 PM
dataway's Avatar
I see NAPA sells the barrel type .... I'm thinking those might work anyway long as one end of the barrel is the same angle as the funnel shaped type, and it looks like it is. Oil pressure gauge line kits probably use the cheapest parts they can find.
Old 04-10-2020, 10:09 AM
AG's Avatar
AG AG is offline
I've tried the barrel shaped before and it's kind of hit or miss with how the end contacts the nut side. The ones that come with the kits are flat on that side and seal much better. I like you have also been looking for replacements with no luck yet.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
The Following User Says Thank You to AG For This Useful Post:
Old 04-10-2020, 10:31 AM
I've bought a bunch of unions over the years, just to get the two cap nuts for the barrel shaped ferrules.
The cap nuts for barrel shape are a tad longer and have the taper/angle in the bottom so they squeeze instead of crushing long ways.
Need to match cap nuts with ferrules
Clay
Old 04-10-2020, 04:20 PM
dataway's Avatar
Jeez, there is the solution right there ... just get a couple of the proper nuts and I can order 50 of the barrel ferrules for about $6. I think the nuts are just a standard straight pipe thread and should thread onto most gauges and tap locations.
