69 T/A rear leaf springs
For anyone looking for the correct rear Leaf springs for a 69 firebird, Matt (tellyshavilli on PY) has worked on having them made. They are the correct 3 leaf springs and the car sits right where is supposed to sit. It's even at the same height as an original 69 400 firebird convertible I have with the original springs. Very happy with the springs,
Thanks Matt! Last edited by necdb3; 05-15-2020 at 01:44 PM. |
Sorry, I don't know how to rotate the picture.
Heartbeat city sells them. I have a pair and they are spot on
Drive it ! 69 Trans Am coupe 70 Trans Am 76 SE 455 hardtop 87 GTA 89 Turbo TA 02 CETA Convert |
How much are they?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Heartbeat has them for $420.00
Yeah but how much is the shipping to Cali on a set of leaf springs?
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
How about Eaton Spring
http://www.eatondetroitspring.com/db...rtsinquiry.php |
You would have to check but the car sits where it should. That's worth it to me. Seems almost all spring replacements sit to high. That was the reason I replaced them in my car, somewhere along the line someone changed them and they were 2" too high. Looked like 4wd height to me.
Eaton doesn’t even acknowledge they exist. I talked to a guy there a few years ago that called himself Mr. Spring, it was a waste of my time. The guy was a rude idiot that thought very highly of himself.
Another view with the car levelled out
That's a lot of wheel well showing above the tire in the front. New coil springs too? Nice looking car.
Yes, replacement springs were installed in the front also and I'll be correcting that as well.
Guys, I want to make sure that I only speak for the use of the springs that I got through Matt. I don't know that they are the same spring as the ones at Heartbeat. They could be, but I cannot verify that.
Pretty sure Matt’s are his and his alone. Not even sure he has many more left. Guess I better get a set before he sells out Sent from my iPhone using Tapatalk |
I believe that Matt and Heartbeat collaborated on the springs so they are identical to one another. I'm happy to have a set for my car.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
Heartbeat city is incorrect . The supplier I worked with is Bob at Camaro Specialties (716-652-7086 )he has them and that’s who you should contact for getting the best and most accurate set of 69 Firebird Trans Am rear leaf springs that are available . thank you
Matt, Are these a 3-leaf spring as indicated in the original post or a 4-leaf? I was of the understanding that 69 T/A had 4-leafs originally. Sent from my iPhone using Tapatalk |
They are 3 leaf and that’s exactly what 69 TAs have from factory
