Good deal on valley pan
Thought I’d share this- this is a good price for a new valley pan-
https://www.ebay.com/itm/182339225696
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
The Following User Says Thank You to JC455 For This Useful Post: | ||
Do you know if that will work with Solid or Hyd roller lifters?
Most valley pans need to be clearanced for roller lifters.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
the early non egr pans dont need clearanced for most roller lifters, this looks like an early pan. almost even a copy of the original tomahawk aftermarket pans?
This says TOMAHAWK right across the front pyramid, so it should clear roller setups, since Ace designed it for that purpose... unless someone is copying the Tomahawk pan- it's China, so ya never know... I'm hoping there's only one manufacturer, and that this is a genuine Tomahawk valley pan- I guess I'll find out in a week or so.
Thanks for posting. That's a great deal - and appears to be the legit Tomahawk part because it's $149 on the Inline Tube website, which is the same price as JBP.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
Last one I bought was from a Pontiac dealer for about 75$ I thought that was expensive at the time
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
strange its $149 at inline because the ebay link is inlines ebay account motorcitymusclecar, & they have to pay ebay seller fees of ~10%.
Thanks, after I got out my 6" magnifying glass I too could discern the Tomahawk logo
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
The Following User Says Thank You to 1968GTO421 For This Useful Post: | ||
Lol- they mention it in the item description
Out of curiosity, why do I see daylight through the PCV hole in the first photo? If it is a true Tomahawk piece, then I would suspect that someone just got carried away with Photoshop.
The Tomahawk is a copy of the 1970 valley cover. I run one, looks just like that and it clears roller lifters. I had to gring the top of the bolts for my Megga Brace though.
