Changing multiple cam on dyno
Just wondering if anyone has a good way to get the lifters out of the way during cam changes. Not having to remove intake and valley pan would really speed things up. And time is money when it comes to dyno sessions.
Maybe a 8 of those telescoping magnet that fits the pushrod holes? You need 8 of those for sure and four guys holding it up. Good luck
impossible Pontiac is not a LS where you can use to long dowels to hold up the lifters .. If it can be done I can't wait to hear how.... Your loaded $$$$$$ just take it apart .. Or magnetic pushrods Build a fixture that sits on the heads .
I was thinking about coat hangers, go down through pushrod and hook tie-bars to pull the up.
Just looking for something outside the box. |
Very helpful, thanks
Coat hangers cut and looped around the tie bars. And the other end wrapped around the valve spring. Long skinny needle nose pliers can help. Also a skinny magnet can help,go get surgical my friend!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.854@160.12 in Brainerd MN 7/2024 |
The Following User Says Thank You to S/st 54 For This Useful Post: | ||
My 1st set of roller lifters could do that.
They had springs on each lifter against the tie bar, when no pushrod pushing it down they would 'pop' up the lifter so the wheel was higher than the cam bore.
I have used them on small black Chevy’s before. They work great!
How bout 16 of those telescoping magnets and use clothes pins to hold them up, like we held the lifters up on a Y-Block ford.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
I wanted to say 16 telescoping magnets but I figured that would cause more money.
With the magnets how would you release the lifters? Don't want to accidentally pull the lifters out of the bore.
You would probably have to use something to push down on the lifter.
I hate to even put this on here because I did a quick search and found this on a Ford site but it may help you. I hope the pic loads
The reason I said 8 magnets so u can stick a pushrod on the other hole to push the lifter down separating the magnet to the lifter.
The lifters were horizontal bar lifters.
Found a pic online (chevy though)
My concern with using magnets is the possibility of magnetizing a metal piece of the lifter.
When is this dyno session taking place?
What do you think Slowbird? Are you going to try to change cams on dyno day?
https://www.andersonfordmotorsport.c...r-5-0l-engine/
these are the ones in the picture a few posts up.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac. 70 Formula |
Id like to test cams, we'll see.
