Old 06-13-2020, 09:23 PM
67428HO 67428HO is offline
Default 67 Firebird oil filter with 1 3/4" headers
Hi , What type of oil filter to use besides Fram PH 25 on 67 Firebird d port Hedman 1 3/4" headers? Thanks!
67428HO
Old 06-13-2020, 09:48 PM
Steve C. Steve C. is offline
The Wix 51045 Oil Filter is a popular "small" filter often used in confined areas.
4.828" in length and 2.921" in diameter.
Old information here:
Old 06-13-2020, 10:41 PM
tom s tom s is offline
Do you have the RA oil filter adapter on it that kicks the filter back?Tom
Old 06-13-2020, 11:11 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
i use a NAPA 1045 for the same reason
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 06-14-2020, 08:09 AM
chuckies76ta's Avatar
I have a 68 Firebird which has Doug's D-port headers. I run the Wix 51258 oil filter. I change oil once a year. I remove the 3 bolts that hold the housing on, change filter and install. If u put a thin film of oil on the gasket that meets the block you can use the gasket over and over. Use a silicone of your choice and glue gasket to oil filter housing.
Old 06-14-2020, 09:26 AM
Might be of interest...
Headers: Solving An Oil Filter Clearance Problem
http://www.pontiacstreetperformance....iladapter.html
Old 06-14-2020, 10:15 AM
ponyakr's Avatar
ponyakr ponyakr is offline
Ran the standard size filters on all our 1st gen Bird drag cars, with 35270 Hedman headers. We used the NAPA 1258, which is said to be the same as the WIX 51258.
But, if the filter side is too close to a header tube, the smaller diameter filters are available in at least 3 lengths, if I remember correctly. These filters also fit some LS engines. So, they are plentiful.
For those who like the K&N filters, with the nut on the bottom, I think HP-2006 is the number for the 4 3/4" x 3".
https://www.oreillyauto.com/detail/b...hp2006/4396007
Sometimes a filter cross reference is helpful. But, sometimes some filters listed are not exactly the same size. So, you always need to check the specs, before buying a filter you're not familiar with.
https://www.oilfilter-crossreference...vert/NAPA/1045
Some here always badmouth the smaller filters. Others have used 'em without problems. Seems that no matter what product I look up reviews for, some say it's great, some say it's trash.
Old 06-14-2020, 02:57 PM
JLMounce JLMounce is offline
This is the filter I use in my header equipped 1969 Firebird. I’ve never had a problem with them.
-Jason
1969 Pontiac Firebird
Old 06-15-2020, 03:56 PM
1965gp 1965gp is offline
The top of the line purolator filter is much smaller than normal. I get mine at advanced auto
Old 06-15-2020, 10:08 PM
ANDYA ANDYA is offline
I'm amazed. I have a 69 Firebird with round port Dougs and I can easily fit Wix 51049 which is the larger 1qt filter. I'm using the 90 degree filter adapter and have no problems getting filters on and off. Personally I would try and run the long branch adapter and get the largest filter I could to fit. Pontiac engineers used the pf24 size filter for a reason and I would attempt to try and get a filter of at least that size to fit. I like the larger filters due to increased capacity and larger filtration area.
Old 06-15-2020, 10:30 PM
GTOLou GTOLou is offline
Prolly round port vs dport.
Old 06-15-2020, 10:44 PM
I run the large filter with the long branch filter adapter with 1 3/4 headers without a issue.Tom
Old 06-16-2020, 09:17 AM
David Jones's Avatar
Baldwin B30. The largest "small" filter.
Old 06-16-2020, 09:28 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Wix 51522 is what I use for header problems.
https://www.fleetfilter.com/filter/51522.html
Old 06-16-2020, 09:47 AM
I run Baldwin B9s and if need shorter run the B39.Never have had to run the small diameter filter.Tom
