Old 08-24-2020, 07:44 PM
rememberfireball#22's Avatar
rememberfireball#22 rememberfireball#22 is offline
Default Starting after 6 months
Back in April I had accident in my pick-up and broke my leg and some other things. My 68 GTO has been sitting in garage since day of accident. I hope to be able to get to garage in a couple of weeks and start car. It still has quardjet that Cliff Ruggles rebuilt several years ago and ign has been switched to electronic. What precautions do I need to take in process of starting and driving again? Thanks, Mike
1968 GTO Numbers matching 400 H.O. 4-speed 3:55
1964 T-Bird 46,000 Actual Mile
1928 Model A
2009 Lexus
1981 Dodge D-100
1976 Cadillac Eldorado Convertible
19631/2 Ford Galaxie Fastback
Old 08-24-2020, 09:42 PM
6 months?....if it were mine, I'd turn the starter long enough to get oil pressure and just start it. I do the same thing after an oil change.
Old 08-24-2020, 09:49 PM
68pongto's Avatar
68pongto 68pongto is offline
Exactly what Greg said. Check the battery, maybe a shot of starting fluid, hit the key. I have cars I have forgot I even had and started them a year or two later after sitting.
Old 08-24-2020, 09:52 PM
6 months equates to about a week for me. Put a new battery in it, stick the key in the ignition and turn it. That is what I did a month ago with one of my Pontiacs that I haven't started since the 1999 POCI Convention.
Old 08-25-2020, 03:18 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
I had a 68 GTO stored under a building in a heated/controlled space for 9+ years. I needed to move it.
  • One tire was low, so we fixed that.
  • The rear drums were stuck, so I had to pound them off with a maul.
  • Replaced battery, added 1 gallon of gas to the gas that remained in the tank, drizzled some gas in the carb (had electric fuel pump)
  • Replaced the battery.
  • checked oil
Turned key, fuel pump hummed to life. No leaks. Then I pumped pedal twice and turned key to start. I believe the engine spun over twice before firing. I feathered the gas for 15 seconds and it then idled.
If my car could do that, your car should pop off right away without trouble!
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 08-25-2020, 03:27 PM
Stuart's Avatar
Stuart Stuart is offline
I store my summer cars every winter, and sometimes it's six months before they're driven again. I just start them up and they're okay. Unless your car has a running clock or some other constant current drain, chances are the battery will be fine - if it was in good shape before and was fully charged the last time the car was driven it probably still has plenty of juice left.
Old 08-29-2020, 08:59 AM
300deluxe's Avatar
300deluxe 300deluxe is offline
I store my Lemans every year for 6 months....in spring I put battery in it, and crank it over till it starts. I always run 95 octane non ox gas in it.
1968 Lemans 350 HO
55 Chevy 210 2 door post, future Two Lane Blacktop car
Old 08-31-2020, 06:01 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
Not that its recommended, but some of my cars will sit for years between runs. Good, Non-ethonal fuel is a must. Have always been surprised how well they will run. Been doing that for about 14 years now. First time I left a car sit for more than a year, I thought I was going to be rebuilding something, but was pleasantly surprised. I think the key is the fuel not going bad & then the storage location being climate controlled helps possibly more than the above. not so much heat, but keeping the humidity away. Bad things happen over time, but I would not think in 6 months. My 79 T/A has not been started in 5-ish years. Was lightly fogged beforehand. That car Still has orignal exhaust on it & I would rather risk a fuel problem than putting condensation through the pipes too often.
about 12 years ago, a friend & I pulled a parts car out of storage that was in a semi-open shed for about 10-12 years. fuel smelled like turpentine, but just for grins we threw a battery in it & dumped some fuel down the carb. not only did it start but we drove it on to the trailer. But, the brakes had failed, so that part was a little sketchy. It was stripped for parts, so I would not have tried that on any other car that had a future.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 08-31-2020, 12:03 PM
Wouldn't hurt to un-plug the power from dist cap (HEI) and crank it over some (without starting) to get some oil working towards the top.
Many ways of prepping - and not prepping - for restarts.
It's all up to you and how much time you want to invest.
6 months inside a garage - would probably just spin it some with starter (without starting) - and then hit it.
If it was much over 6 months
I pull the distributor and run a drill tool on the oil pump.
Re-Install
Pull the spark plugs and give a small squirt in each hole.
Crank it over with coil wire unplugged.
Replace spark plugs.
Then hit it
Its old fashioned now - but its not in vain.
Old 09-03-2020, 07:04 PM
Thanks for all the advise. I removed hot wire from coil and just cranked it over for about 25/30 seconds. It quickly built up between 40/45 lbs oil pressure on under dash Stewart/Warner gauge. I then reconnected wire to coil and she fired up. After 6 months in bed/recliner , I forgot how much fun it is to do a burnout.
1928 Model A
2009 Lexus
1981 Dodge D-100
