Old 09-02-2020, 01:14 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Default 1962 GP Brake Drums 5x5?
Are these available anywhere or do I need to look for used? Anyone know the turn limit dimension? Thanks
Old 09-02-2020, 07:27 PM
DiamondJim's Avatar
So far I’ve found zero Brake drums available for my 62 GP drum brake car
Old 09-02-2020, 08:34 PM
stevep's Avatar
stevep stevep is offline
I have an NOS drum
Old 09-02-2020, 08:41 PM
DiamondJim's Avatar
Found them at Ames. They’re 139 each. Anyone know the max inside turn diameter?
Old 09-02-2020, 10:44 PM
Should be on the outside of the drum.
Old 09-03-2020, 11:58 AM
webfoot's Avatar
webfoot webfoot is offline
Look at rock auto for a 64, they fit my 62 just fine.
http://forums.maxperformanceinc.com/...d.php?t=821385
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 09-03-2020, 12:07 PM
389 389 is offline
I think the limit is .060... It used to say it on the drum, 11.060 Max...
I wonder if 80s or 90 Buick, Olds, Chevy, Pontiac or Caddy drums would if.. Chevy pick ups are also 5x5..
Old 09-04-2020, 12:50 AM
DiamondJim's Avatar
I’m guessing the rock auto 64 drums will only fit the rear on my 62. Any other options for the front?
Old 09-04-2020, 01:11 AM
DiamondJim's Avatar
I just checked Rock auto for the 64 drums. All they list for 64 are 4.75 x 5. My 62 is 5” x 5.
Old 09-04-2020, 10:10 AM
AZ64GP AZ64GP is offline
You have to be careful what you order from RockAuto for our cars. I made the same mistake and accidentally purchased drums from them in the wrong size/bolt pattern for my '64 GP. I can't remember what I did, but I was able to find the correct drum size and bolt pattern by searching.
Old 09-04-2020, 10:40 AM
Stuart's Avatar
Stuart Stuart is offline
Our host Ames Performance has brake drums listed: https://secure.amesperf.com/qilan/Se...sub_rowid=1098
Old 09-04-2020, 03:17 PM
DiamondJim's Avatar
Thanks. $556. for 4 brake drums is a lot of money. I was trying to find the $40 brake drums instead of the $139 dollar ones
Old 09-05-2020, 12:14 AM
DiamondJim's Avatar
Ok. I found 21” x 2-1/2” 5 x 5 on rock auto for the rears at 49 each. Apparently early 64 was 5 x 5 and then it changed to 5 x 4-3/4 from mid 64 to 70. Centric 12362025. Do your own research but these should work on the rears of our 62’s. I’m buying the fronts from Ames for 139 each. Thanks all ����
Old 09-05-2020, 01:30 AM
DiamondJim's Avatar
Should say 11 x 2-1/2 not 21
Old 09-05-2020, 09:02 AM
Stuart's Avatar
The bolt pattern on full size Pontiacs was 5x5 all the way until 1976 (and even later than that on some models, I believe), so Rock Auto's application information apparently isn't correct. Hopefully the ones you get will be okay.
Old 09-05-2020, 10:56 AM
Poncho60 Poncho60 is offline
Stuart is correct. GPs got the smaller bolt pattern starting in 1969. My carpool partner bought a 78 Bonneville new w the 400 motor and it had the 5x5 pattern. I think wagons may have had it as well.
Old 09-05-2020, 12:45 PM
pfilean's Avatar
pfilean pfilean is offline
The front are 2 1/2 - the rear are 2. Maybe Rock Auto is a confused about the shoe size as on the bolt pattern.
Old 09-05-2020, 12:51 PM
Stuart's Avatar
That's right..I forgot the OP's car was a GP. Of course, Pontiac went to the new design in 1969 which was an extended version of the A body car chassis.
When looking for parts for a 1962-1968 GP, sometimes it's easier to search for Catalina parts instead - some vendors will confuse availability with the 1969 and later cars.
Good point, I didn't catch that when first reading it - the rear brakes are 2" wide on these cars.
Old 09-06-2020, 04:30 AM
DiamondJim's Avatar
Are the rear drums on a 62 and a 64 GP the same? Are both 11x2 5x5. ?
Old 09-06-2020, 08:31 AM
Stuart's Avatar
I believe the rear drums should be the same on all full size Pontiacs from 1959 through 1964.
