Old 09-02-2020, 09:11 PM
Brewster's Avatar
Brewster Brewster is offline
Default Exhaust Shroud
Looking for an exhaust shroud for driveside stove pipe for my GTO. Please let me know what you have and thanks for looking.
Old 09-02-2020, 10:02 PM
Scott Thelander's Avatar
HO or std manifolds ? or
Old 09-03-2020, 07:39 AM
Brewster's Avatar
Ram Air so standard. The punched type not the square welded. Thanks should have noted.
Old 09-03-2020, 04:31 PM
Dick Boneske's Avatar
I have the sheet metal shroud for the driver's side for a '67. If that sounds like what you need, I'll send pictures.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-03-2020, 09:25 PM
Brewster's Avatar
Brian@shirleylodge.com
Thanks Dick
Old 09-03-2020, 09:31 PM
uh
"Ram Air so standard" I dont have one of these either
I thought it was for a 69 .... Im out .... time for fresh batteries in the crystal ball
Old 09-03-2020, 10:06 PM
Brewster's Avatar
Scott, did you have that upper ram air cable and connection link?
Old 09-15-2020, 04:53 PM
Brewster's Avatar
Still looking for shroud if anyone would like to sell?? Thanks for looking!
Old 09-26-2020, 05:31 PM
Brewster's Avatar
Would also entertain a Ram Air IV shroud. Either way it needs to be an original. Thanks
Old 09-26-2020, 05:34 PM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
I have several factory shrouds for various models. Have you got a pic or illustration to reference? Thanks, Bob.
Old 09-26-2020, 06:49 PM
Brewster's Avatar
Default Shroud
To be honest Im not 100% sure what came in a later built June Arlington car.
I do know that 69 Ram Air III cars got one of two shrouds. The RAIV shroud was used assuming when the inventory on the RAIII shrouds ran down. It is the folded & spot welded shroud and the RAIII is the pressed one.
There is also an inner heat shield the bolts on first. Those look the same in either case.
ID:	550345   Click image for larger version
Old 10-28-2020, 06:26 AM
Brewster's Avatar
Still looking for a shroud if someone has one please contact me. Thanks
