Old 10-05-2020, 10:56 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Oldsmobile flywheel question
I thought I heard that Pontiac manual trans flywheel....will work on Olds V8.
Have a 75 400 Pontiac flywheel...Will this fit/work...on 73 350 Olds?
Old 10-06-2020, 11:08 AM
Mr. G Mr. G is offline
I am pretty sure that a Pontiac flywheel will not fit the bolt pattern of the Oldsmobile. I have had about 5 442s over the years and once I had a pile of flywheels that were all Pontiac except one which did fit the Olds, but not the Pontiacs.
Old 10-06-2020, 09:38 PM
4dblnkldude's Avatar
Good question. I did a 4 speed conversion in my 69 firebird in 1996. I bought the flywheel, shifter, and muncie of my buddy Chalie. He was going to put it into his 72 cutlass with a olds 350. He only sold it because his crank was not drilled for a pilot bearing. I put everything in my car. Did the guy he got it off of have a poncho flywheel? Maybe so...
Old 10-28-2020, 09:14 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
NO ! Those parts do not interchange on Pont and Olds .. a 73 350 needs a Olds 350/455 flywheel 1968-1976 also 99% of Olds V8s were Automatic and the back of crank is not drilled for the pilot bearing/bushing unlike our Pontiacs and Chevrolets so if you are going with that engine prepare to do that first or factory in all the cost first.
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
