Old 10-18-2020, 02:16 PM
starlightblack's Avatar
starlightblack starlightblack is offline
Default Crane Cam 284071
GRIND # SSH-322-NC
Anybody ever run it, have specs? Or an old Crane Catalog
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
Old 10-18-2020, 04:40 PM
ponjohn's Avatar
ponjohn ponjohn is offline
SS-322-NC Mechanical,Rough Idel/Good Mid-Range HP
Intake open close BTDC 54 ABDC 88
Exhaust open close BBDC 88 ATDC 54
Adv Deg Dur 322
Dur @.050 252/252
Lash Hot .022/.026
LIft .526/.526
Out Of Cranes 1975-76 Book
Found this - no H though.
The Following User Says Thank You to ponjohn For This Useful Post:
Old 10-19-2020, 01:26 PM
Many thanks, much appreciated.
Old 10-19-2020, 04:26 PM
taff2's Avatar
taff2 taff2 is offline
I ran a very similar Crane solid lifter cam in my old n/a 400, it made 575hp with ported iron heads and I ran 9.60's in a 2600lb car
The Following User Says Thank You to taff2 For This Useful Post:
Old 06-16-2021, 09:58 PM
Chris.H's Avatar
Chris.H Chris.H is offline
Adv Deg Dur 322
Dur @.050 252/252
Lash Hot .022/.026
LIft .526/.526
HEY PONJOHN I have the same cam SSH-322-NC any info on the H or is it irrelevant on the other end is stamped x7763
Old 06-17-2021, 12:46 PM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
SSH-322-NC HYDRAULIC FAIR IDLE, GOOD MID-RANGE H.P.,DURATION 310-322, LIFT 465-483, INTAKE OPENS 45 BTDC, CLOSES 97 ABDC, EXHAUST OPENS 97 BBDC, AND CLOSES 55 ATDC. 3200 TO 5800 RPM. I have a pic of the cam card but cant get it to load.
