Old 10-26-2020, 09:02 PM
gogtogo's Avatar
gogtogo gogtogo is offline
Default 10” Rim Stock 64 GTO
Good evening. Anyone have any luck or experience with a 10” Rim & M/T 275 Pro under a stock 64-67 A-Body? What moods needed and offset ext?
Thank you
Old 10-27-2020, 08:58 AM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Check the archives...information right at your fibgertips.
Old 10-27-2020, 05:03 PM
gogtogo's Avatar
Any other tips, or I’m I on on a wild goose chase in the archives?
Old 10-27-2020, 05:11 PM
Gonna be tight.
I can't offer up an offset for you, but most stock 64-65 A Bodies that I am familiar with (can't offer up much on the 66-67 A Body) came with 14x6 wheels with a 4.25 back-spacing with a 5x4 3/4 bolt pattern.
Some here have increased the back-spacing to 4.75 (an additional 1/2) and went with a 15x7 or 15x8 wheel and a 255 size tire fit safely.
Maybe some others here can chime in?
I 'think' to clear most aftermarket, more than stock type disc brake calipers you'll need an offset of 3.5", but do not quote me on that.
Old 10-27-2020, 05:40 PM
Mike Davis's Avatar
I have not been able to get a 10" under my 66. Tried a few. Currently running a 15x8 with a 4.5 backspace with a early width housing. I could use a 5" backspace but most aftermarket wheels I like jump from 4.5 to 5.5
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 10-27-2020, 05:47 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My '65 I fit a 275-60-15 in an 8" Trans Am Turbo wheel that is 4.5 back space and the original rear end. The Zero offset Cragars I have on the 64 Impala hit on the outside of the wheel well/fender lip.
Skip Fix
Old 10-27-2020, 06:04 PM
Scott65's Avatar
Scott65 Scott65 is offline
Centerline in the past offered a 15×8 1/2 with a 4 7/8 backspace that might help if it's still available.
Old 10-27-2020, 08:54 PM
Mike Davis's Avatar
They closed up shop a few years ago and I had a deposit on a set of wheels. They have reopened ( I think the name was bought out) and the only "race" type wheels they offer are the Autodrag and Convo Pro. But do have a 15x8.5 w/ 4.75 back space.
Old 10-27-2020, 09:23 PM
gogtogo's Avatar
I currently have a 15x8 as well. Can’t remember off set off hand but sidewalls rub inter fender well. I have measured a few times and think it could be done but haven’t come across any donor wheels to try. 15x8 Corvette Rally’s fit well years ago but to heavy and outgrew the look.
Old 10-28-2020, 07:46 AM
Hooter's Avatar
Hooter Hooter is offline
I run a 275/60/15 on a 8" rim and it's a snug fit up in the wheel well, but doesn't rub anywhere. I'm not so sure you can go much wider either.
67 Bonneville ragtop
Old 10-28-2020, 08:21 AM
slowbird's Avatar
slowbird slowbird is offline
We run 10" rims on our 65. The back spacing is either 4.75 or 5, sorry I can't remember which
Old 10-28-2020, 10:01 AM
bluegoat65 bluegoat65 is offline
My 65 I run 8 inch rim with 5.5 backspace with 28 x 9.0 slick. perfect fit. Problem with our 64-65 cars is that they were pre wide track. We are one inch narrower than the 66-72 A bodies. I tried a set of Hoosier 10.5 quick times on the 8 inch rims with the 5.5 backspacing and it rubbed lightly on the frame rails and was right at the lip of the wheel well. I wasn t to comfortable with that and went with the 9 inch slick from there. Sounds like mini tub time possibly.
Old 10-30-2020, 01:02 AM
lust4speed's Avatar
Thinking that for every inch the rim grows, the section width increases a half inch on the 15" rims around 8" wide. So going from an 8" to 10" rim the tire width is going to go from about 11" to 12". On my '67 after trimming the fender lip and tapping in any areas where the inner fender protrudes out, I have exactly 12" of clear space. Which means that just the normal movement of the tire would have it rubbing constantly with a 10" rim. I have about a 1/2" each side of the tire with the 275/60R15's on an 8" rim with 5.25" backspace.
I ran a 28x10.5 slick which was 12" wide mounted up, and I could push it up into the wheel well and it would stick. That was past what the suspension would compress to, but it does show that things got a little narrower at the top of the wheel well.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
Old 10-30-2020, 09:30 AM
Skip Fix's Avatar
That is what I saw using the 275-60-15 on my 65 real tight both sides. My 64 Impala is even tighter just needed a different offset.
Skip Fix
Old 10-30-2020, 10:05 AM
blubiu65 blubiu65 is offline
I have a 65 with the 68-72 rear end width. I have a 275/65/15 drag radial on it with plenty of room. Weld Wheels 15x8 with 5.5 inches of backspace.
