Old 11-20-2020, 09:27 PM
mchell's Avatar
mchell mchell is offline
Default Harmonic balancer question
Got a quick question:
I think my balancer has slipped.
When looking at a Pontiac harmonic balancer key way. What is the corresponding timing degree in relation to the key way?
Don’t have another one laying around to compare,.
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 11-21-2020, 04:34 AM
lust4speed's Avatar
lust4speed lust4speed is online now
Just happen to have a pic from yesterday. Using the 2A slots, but that's only two degrees off and would be tough to eyeball the difference. Which brings up another point is the damper might only have slipped a few degrees which would be near impossible to discern.
Name:	Timing chain.jpg
ID:	554440   Click image for larger version
Mick Batson
Old 11-21-2020, 05:49 AM
dataway's Avatar
dataway dataway is offline
If it's still on the engine ... use the #1 plug hole to find TDC and check it against the timing marks.
Old 11-21-2020, 08:12 AM
mchell's Avatar
Did that first thing...it appears to be off 20 degrees or so
Still like to see where the balancer key way slot is in degrees. That would verify my findings.
I did order a new balancer (dayco power bond Sfi from Butler),
Old 11-21-2020, 08:23 AM
mchell's Avatar
For those that have a good balancer laying around:
At what degree is your balancer key way clocked to?... 100 degrees, 140 degrees etc.
Your balancer will have to have some marks all the way around to give an estimate of where the key way is normally clocked.
Trying to get a reference on a good one. Sounds like it’s not going to be possible without having a good one right next to mine.
I”m confidant that mine has slipped. Just looking while waiting for new.
Old 11-21-2020, 09:12 AM
johnta1 johnta1 is online now
When the engine is at TDC on #1, where is the timing mark on the balancer compared to timing cover?
Clockwise or counterclockwise from the timing cover mark?
Old 11-21-2020, 09:37 AM
mchell's Avatar
Current situation:
See pic
With Engine at TDC on # 1....note that “zero “ on the balancer is now retarded about 20 degrees
While checking my timing I noticed it was advanced off the chart...dist was not loose, pulled dist and double checked everything and it was ok. Tried adjusting timing but it was wanting me to retard so much that I knew something was wrong as I kept having to idle it up way beyond normal.
That’s what led me to the balancer.
Never had one slip like this.
Old 11-21-2020, 09:40 AM
mchell's Avatar
Counter clockwise....see the pic I just posted
Old 11-21-2020, 09:43 AM
mchell's Avatar
Also,
The uploaded pic looks crappy....try this one
https://share.icloud.com/photos/09gI...aQw#North_Port
If your looking at the pic the white line(on the balancer) is 34 degrees NOT TDC....I use that to reference my total quickly. The white line (kind of hard to see as it’s shaded)on the timing cover is zero.
Old 11-21-2020, 09:53 AM
mchell's Avatar
Anyways,
Sorry for the confusion......every balancer should have the key way clocked at X degrees so the balancer timing marks reference the timing cover marks close enough to get timing.
I was trying a secondary verification by having someone look at a good one that is not on the engine.
My key way right now is clocked to about 100 degrees....should be about 80?
Old 11-21-2020, 10:59 AM
Yes, it looks like it has slipped if the crank is at TDC.
It would be retarded.
What brand of balancer is that?
Old 11-21-2020, 11:25 AM
mchell's Avatar
Had this one for 10yrs ...can’t remember what brand...pioneer? Sfi two piece with the locking ring.
It’s marked with a “PB” brand.
Old 11-21-2020, 11:47 AM
firechicken's Avatar
firechicken firechicken is offline
Powerbond perhaps
Old 11-21-2020, 11:54 AM
mchell's Avatar
Well....should have removed pulley before I posted
See pic....definitely spun
Look at the fresh shiny spots...
https://share.icloud.com/photos/0ww5...NZbYJ1OtlnwVjg
Old 11-21-2020, 12:02 PM
Well, good you found it before it exploded!
Old 11-21-2020, 12:22 PM
mchell's Avatar
And I just ordered another powerbond....was that a mistake?
Any feedback on balancer choice?
Here’s what I ordered:
https://butlerperformance.com/i-2445...tegory:1234723
Old 11-21-2020, 12:34 PM
Did you get the 1st one from Butler?
Might ask them if it may be warrantied?
I haven't had any of those balancers.
Might check it in about 8 years?
Old 11-21-2020, 12:53 PM
mchell's Avatar
Should one avoid this style of balancer at a certain power level?......never gave it a ton of thought thinking these clamp better than a stock unit. But now I wonder.
Old 11-21-2020, 03:06 PM
I've had a Powerbond sfi on my turbo engine for over 10 years without issue.
Maybe you were just unlucky...or maybe mine is about to let go.
Old 11-21-2020, 03:25 PM
mchell's Avatar
Yeah.....I wonder about slinging a two piece 10lb weight from a standstill in an instant....It’s begging to come apart
Probably better using a balancer that is not a two piece?
