I have installed a set of Performance Year exhaust manifolds on a 76' Le Mans and the down tubes hit what I would call the "Chassis Stiffener " bars that run from the frame rails on the side of the frame up to the front crossmember.
I am using 3" down tubes for this application. I am sure that I am not the first person to run into this problem with these "bolt in" bars! Any suggestions on solving this issue? Possibly manufacturing a flat plate that would maintain the rigidity and allow for the down tubes to work or what has anyone else done in this situation? I have had one guy tell me just to remove the bars however the engine puts out over 500 FT LBS of torque and I just cant see the GM engineers putting these bars on if they were not needed! Any feedback would be greatly appreciated. |
Just take them off.
I would try to make them work. They DO help the chassis rigidity. I noticed a difference in ride and drive when I installed a pair of them on my former 1973 GTO. I also would look into if the chassis stiffener from a 1980-90's Caprice would work better. They were flatter steel, and the frame curvature is almost identical. Some drilling would be required.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
