Old 12-20-2020, 06:24 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Default Rust bucket Bird
I recently restarted on my 68 Firebird Project
And since I knew it had some rust problems I was going to start by tearing it down and getting it blasted
I thought just the floor was rusty but man just about every panel has issues
So far the rockers look decent but that's about it
Has anyone else felt like they were going to completely have to rebuild the metal work on their cars?
Any advice?
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 12-20-2020, 06:28 PM
Here's some context:
ID:	556584   Click image for larger version
ID:	556585   Click image for larger version
The Following User Says Thank You to Captainofiron For This Useful Post:
Old 12-20-2020, 06:29 PM
The previous owner "repaired" it by riveting .125" sheet....
Old 12-20-2020, 07:02 PM
72projectbird's Avatar
She's a little crusty, but definitely not the worst I've seen.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
The Following 2 Users Say Thank You to 72projectbird For This Useful Post:
Old 12-20-2020, 07:07 PM
gtospieg gtospieg is offline
Captainofiron...Just work at it one panel or area at a time. I WISH my car had been that solid when I started. 67 Tempest...inner and outer rockers, full floor, full trunk, full quarters, dropdowns, tail panel....I think you get it. Carry on and good luck.
The Following User Says Thank You to gtospieg For This Useful Post:
Old 12-20-2020, 07:49 PM
Thanks guys for the responses, it's just nerve-wracking to take something off and everytime see a giant hole or be able to poke your finger through what was supposed to be steel
Hopefully I'll be able to get it to the blaster early January
Old 12-20-2020, 08:01 PM
1965gp 1965gp is offline
I’m sure I’m in the minority- but does the car have sentimental value? I’ve restored several cars I shouldn’t have because of who owned them. It was worth it to me. Make sure it’s worth it to you.
The Following User Says Thank You to 1965gp For This Useful Post:
Old 12-20-2020, 08:47 PM
I know how you feel. My '68 needed an entire roof plus sail panels and that's on top of all the normal stuff that most of them need...
I had no clue until I decided to sand the primer off. The PO had used expanding foam in all the roof rust holes, sanded it and primed it. Looked great until you scratched the surface. The happy ending is that I got over the shock and just sucked it up and repaired it with donor metal.
Old 12-20-2020, 08:56 PM
It does, it's my first car, my dad got it for me when I was 13 as a project for him and I to work on. That being said I've been going back and forth on buying one in working shape now vs restoring this one
Oooooofffffff expanding foam?!?!? That's pretty bad
Looking over the parts catalog I'm amazed at how many replacement parts you can get now. You but basically buy a brand new unibody
Old 12-20-2020, 09:10 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
You’re staying active and using your hands, which is as rewarding as restoring a car.
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘22 Toyota Sequoia V8
‘23 Lexus LS500 awd
‘95 Ford F-super duty 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles.
The Following User Says Thank You to 455Grandville For This Useful Post:
Old 12-20-2020, 09:35 PM
I still have my first car (which was my dads so I suggest you keep going. It’s one of those things you can never get back
The Following 3 Users Say Thank You to 1965gp For This Useful Post:
Old 12-20-2020, 09:46 PM
Simple Man's Avatar
I've seen worse brought back. Go for it!
be a simple...kinda man.
The Following User Says Thank You to Simple Man For This Useful Post:
Old 12-21-2020, 07:41 PM
thepontiacman's Avatar
Good luck with your project.
If you decide it's too bad, I have a 68 Firebird project in AL for sale.
Sent from my Moto Z3 Play using Tapatalk
The Following User Says Thank You to thepontiacman For This Useful Post:
Old 12-23-2020, 05:53 PM
Pecosbill's Avatar
If you’ve got the resources, both in terms of money, time and also have a good bodyman or have those skills yourself, go for it. These cars need to be fixed and consider it your task to save another one from the scrap heap. When it’s done not only will you be proud of what you’ve accomplished but you’ll have the pride of knowing that your work will most likely be here being enjoyed by someone long after you’ve gone.
Pecosbill
The Following User Says Thank You to Pecosbill For This Useful Post:
Old 12-25-2020, 11:15 PM
CDub76's Avatar
CDub76 CDub76 is offline
To answer your question: Has anyone else felt like they were going to completely have to rebuild the metal work on their cars? Oh yes! When finished, my 67 GTO project will be mostly replacement sheetmetal. The deeper I get into it, the more rust I find. (Tried include a pic but couldn't figure it out.) I'm in the process of replacing the rear LH inner sail panel to roof support as well as the rear roof support and window channel. I've already replaced the complete firewall/cowl section, floor pan and toe boards. The only original reusable parts are the doors, deck lid, roof and LH front fender. It's a lot of work but I'm learning a lot and really enjoying it. I recently restored a 79 Trans Am that had some rust issues but not like this.
The Following User Says Thank You to CDub76 For This Useful Post:
Old 12-26-2020, 12:20 AM
Devil's advocate:
How much is your time, sweat and skill? When added up this is not a bad deal at all:
http://www.dynacornclassicbodies.com...irebird-coupe/
Old 12-26-2020, 12:32 PM
max 93 max 93 is offline
I would be mad if I ordered a68 Firebird and that showed up.
Old 12-26-2020, 02:55 PM
Hikin Mike's Avatar
Yeah I saw that too.
- Mike
Old 12-26-2020, 03:46 PM
Let us hope it is simply the same pic on the website and not the wrong shell.
Old 12-27-2020, 11:13 AM
Devil's advocate:
Haha I've had that in the back of my mind this whole time.
I guess we will see once the media blast is done how much is truly left
