Steering Column Codes
Anyone know how to decipher the code on the steering column. I have a few in my shop and am curious about them.
I think one of them reads as follows: 9 a 192 |
Originally they had a two letter code as seen on the broadcast sheet. If I recall it was a paper decal. Box 60 of the broadcast sheet had the code and color of the column listed.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Thanks, on the column in question the code is stamped into the metal near the base just above the firewall plate. I assumed the 9 may be for 1979, A-maybe the month? 192-? Colour? or A-colour? 192 day of the year? I have a couple of build sheets I will see if they correlate any way.
Related as an FYI, underneath the foam gasket on the bottom end of the firewall plate was a green paint marker check mark. Def. a factory thing. |
Example of the original decal as found on these columns. Also reference: https://forums.maxperformanceinc.com...d.php?t=782161
