Tri-Power Tech 57-66 Tri-Power Talk
Old 02-22-2021, 05:27 AM
ponchorob ponchorob is offline
Default lookin for 66 tripowwer center carb
....lookin for a 66 center carb.... any suggestions...
cant get a 66 carb from a 66 2bbl engine but dont know if its the same...
any other suggestions
Old 02-22-2021, 10:58 AM
Dick Boneske's Avatar
There are many versions of the Rochester 2G that will work on a '66 Tri-power setup. A correct "575" carb will be pricey--they're the hardest to find since they were used one year only. The only Tri-power carb that is rarer is the AIR version for '66, which has the ported vacuum advance port also used on '66 Olds. If you're interested, I have quite a few carbs, restored and unrestored that will work. I also have four correct "575" center carbs. PM if interested.
BONESTOCK GOATS
'99 Bonneville SE Sedan
