Old 02-26-2021, 12:53 PM
dld's Avatar
dld dld is offline
Default 70 dash help
Looking for some help on my 70 TA .
1 in pic one . this bulb hole is larger? what goes here ?
2 in pic two . this stud is for what wire . Ground?
3 in this pic . im showing the PW harness . but with it are two other wires . can you tell me what they are for.
thanks Don
ID:	561603   Click image for larger version
ID:	561606   Click image for larger version
Old 02-26-2021, 01:58 PM
First one takes the gray bulb holder with the fiber optic lead coming out of it. The lead goes down to the back of the ashtray bracket.
Old 02-26-2021, 02:07 PM
2nd pic... plug from that connector goes to the tach lead on the distributor. Brown wire(?)
Mid to late '70's there was an L shaped plug that slid into that particular male connector & one a 1/2" away. Am not in my shop but in town, looking at guages out of my '77 Y82 4spd project.
Old 02-26-2021, 02:42 PM
dld's Avatar
dld dld is offline
Is this it . (see pic) i'm assuming this passes through the FW to engine.
some one looks to have made some alteration. car had a MSD in it that is now gone .
big help
I found the socket and fiber cord in AMES .
Old 02-26-2021, 11:47 PM
Formulabruce's Avatar
Taking a Stab at pic 3..
Old 02-27-2021, 12:05 PM
dld's Avatar
dld dld is offline
I like how you did that with the pic. I need to learn that .
But after thinking it over many! times . I pulled the door harness out. That was packed with door stuff . looks like the P/W are the green and blk. I had forgot the car has P/L . looks like that matches up with the orange/blk tracer wire and the orange wire. No explanation on the colors not matching on the P/L . door side .
This only leaves me with the pink wire that someone added connector to.
The door locks are tied into the seat back release also . That's another circuit that works on a separate door jam switch. My understanding that if you got P/L the elect seat release was included.
I ordered a wire diagram from AMES hope that helps. The books I have don't have a good diagram
see pic
Thanks for your input
ID:	561659   Click image for larger version
