Old 03-06-2021, 12:51 PM
79firebird_99TA's Avatar
79firebird_99TA 79firebird_99TA is offline
Default Clear Coat peeling on the `99 Trans Am
I have been debating on getting the TA wrapped but obviously have to deal with the clear issues beforehand on the front and rear bumpers.
It appeared that the base coat was ok when I started and I was careful not to hit it when sanding. You can't catch a nail on the clear so I think I'm good; it's ready to be wrapped.
But ... I'm curious, what would the next step be if I want to restore the bumper? Polish the dull base coat and wet sand the good clear before spraying new clear?
79 Firebird/`70 400 with `77 6x-4s shaved .065"/4 speed BW ST-10/Cliff Q-Jet/XE268/3.08
99 Trans Am/383 LS1/TSP headers and catback/custom grind cam/Vigilante 2500/Strano springs and Konis
08 Corvette - Base
(SOLD) 75 Corvette/L48 350 (LSx -4L60E one day)
Old 03-06-2021, 01:29 PM
TAKerry TAKerry is offline
Not sure what that is a picture of, maybe around a headlight? I know nothing about paint but it looks like you have a lot more going on than clear coat peeling.
Old 03-06-2021, 01:52 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
That clear has to be stripped or your wrap will lose adhesion too.
The Following User Says Thank You to Rob in NH For This Useful Post:
Old 03-06-2021, 03:29 PM
I know nothing about paint either, but when I applied some wax to the base coat, it does come back. It's going to have to be cleared since it's been sanded off.
08 Corvette - Base
Old 03-06-2021, 03:46 PM
Here's a shot after a quick compound buff.
08 Corvette - Base
Old 03-07-2021, 10:57 AM
Its called "delam" or delamination. GM was plagued with it in the 90's. There is basically no stopping it without stripping.
As mentioned, if you put wrap on it, it will still continue to delam, only now it won't be just clearcoat coming off.
The Following User Says Thank You to Chief of the 60's For This Useful Post:
Old 03-07-2021, 01:42 PM
I'm going to go ahead and polish it for now, knowing that in the future It'll be a strip and paint job. The rest of my paint is in great condition. Not bad for a car with 372,000 miles on it.
08 Corvette - Base
Old 03-29-2021, 10:37 AM
Formulabruce's Avatar
Water base paint tech from the early 80's that was never improved upon until around 2003 ish.
The fix is to remove bumper, strip by sanding, repaint sealer, base and use a solvent clear coat
