Old 03-07-2021, 03:16 PM
Default 1970 T/A Shaker repair question
I found this 1970 shaker base in a stack of air cleaners in my storage. The previous owner decided to drill holes in the walls to let more air flow in. Kinda defeats the purpose of a shaker since drilling holes in the sides sucks in hot air, not cool air.
Anyway, how hard would it be to repair? I have a shaker top that should match this.
ID:	562248   Click image for larger version
Old 03-07-2021, 03:18 PM
Ignore the pictures of the shaker. They are for a 1974 GTO.
Old 03-07-2021, 04:16 PM
weranc55's Avatar
weranc55 weranc55 is offline
I don’t know if it’s worth repairing it. The hole he drilled on the side with the indentation will be very hard to fix
Old 03-07-2021, 06:59 PM
unruhjonny's Avatar
Honestly, my only thoughts on repairing one like that would be to cut out the dropped base, and mate it to the sides and folded rim of a (relatively undesirable) full sized car air cleaner.
I believe that the 1968 full sized car has the correct single snorkel too.
1970 Formula 400
Old 03-07-2021, 10:40 PM
Norwood's Avatar
Norwood Norwood is offline
You have the skill to do this ridiculous idea? I’d love to see your result.
Old 03-08-2021, 03:48 PM
RAIVJUMB's Avatar
RAIVJUMB RAIVJUMB is offline
I would think it is possible but would make the value of this kinda low. seems more like a prove it can be done situation vrs financially smart.
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
74 SD T/A Admiralty Blue Auto
others that reside in the barn too
Old 03-08-2021, 05:14 PM
very interesting
Old 03-08-2021, 05:19 PM
Originally Posted by Tellyshavilli View Post
very interesting
Old 03-08-2021, 10:14 PM
NOT A TA NOT A TA is offline
Curve some pieces of sheet metal and panel bond in place inside the base. Then bondo and sand, prime, paint. Sure you'd be able to tell if you could see the inside but really no one would know but the car owner. With the hood open at a show or whatever it'd look like a normal stock part.
Option 2: cut circles and weld in place, grind to perfection. Labor intensive but possible.
John Paige
Lab-14.com
Old 03-08-2021, 10:56 PM
Norwood's Avatar
Now that’s a plan, hope he has a snorkel. How about silver Metal body repair tape or fiberglass on the inside to support epoxy filler on the outside. These are doable ideas that just about anyone should be able to handle
Old 03-08-2021, 11:06 PM
Aus78Formula Aus78Formula is offline
I did this in a previous life. They had holesawed 4 holes in the rear so I found 4 matching 1" sheet metal flat washers matching diameter and thickness, roll them slightly on a large pipe with hammer but not to same amount and tacked around edges before grinding. It was powder coated in a batch of parts so no filler and came out well, could only see outlines of grinding at certain angles so with some work blend in much better. I sold it days later. None of it worth the time or effort but that's what hobbies are about.
