I had bought a set of Hooker headers model 4902HKR and have big problems on the driver side with fitment. One tube is contacting the pitman arm where it connects to the steering box and the steering can't turn all the way before hitting another tube. Pretty disappointing for sure.
Anybody have a good experience with other header manufacturers? |
I am guessing you have the straight Pittman arm? Assuming yes, you need the curved pitman arm. I forget what model/options the curved unit came with, but they are readily available in the aftermarket.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
I don't know what I have for a pitman arm but I'm running Hooker Super Competition ceramic coated part #4107-1 on my 67 with out any fitment problems. Could it be your mounts being worn or the engine not setting level?
67 Firebird Convertible |
99.9% sure he needs the curved pitman arm. My 68 with 350 and manual steer had the straight arm, which does not work with most (if not all) 4 tube headers
The 4107 model definitely has different bends WTF?
The car was built with power steering and it does have a straight pitman arm. This car has been through a lot of hands so who knows what was originally there. Ames catalog (pg. 288) says curved pitman arm will not work with variable ratio PS or cars that have a straight pitman arm. So I don't know if I get a curved arm if it will even work! Cheapest aftermarket curved pitman arm I found was just over $50.
Here are some pictures
place called rare parts makes replacement curved pitman arms about $150 http://fcrcmachine.com/rare-parts-pi...d-power-20798/
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I have an extra original curved pitman arm from a '68 firebird if anyone needs one.
Has been in a box for 20ish years. |
I remember converting a 68 to a 400 from an original 6 cyl with manual steering. I definitely needed the curved arm to replace the original straight arm.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
I believe you can simply replace the arm. I don't think you need to also change the drag link and related components.
The curve is there simply for clearance, the attachment points should otherwise be the same, is my understanding.
Yup, its been years but I believe that is so.
What models came with the curved pitman arm? I have a 69 original 400 car and used dougs. I bought them 15 years ago and no fitment issues at all. They still look great too.....after I cleaned the oil stains off the coating.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
1968 V8 cars came with the curved pitman arm.
