Old 03-28-2021, 04:36 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Default Any word on the #50 replica
Hello all I was wondering if any progress was made on the Paul Goldsmith super duty tribute car? I haven’t seen any thing and the car in a few. I remember it was coming along really nice. I always wanted a road racing 1963. Probably never happen at my age...if so maybe pictures? Tom’s SD intake would look incredible on it.
The Following User Says Thank You to Darren 639 For This Useful Post:
Old 03-28-2021, 12:42 PM
Chiefkey Chiefkey is offline
According to the Hot Rod article the car used the factory transaxle. Any info on what they did to make it last racing 250 miles behind a 421 SD ? Are there any technical articles or details available on the design and construction of these SD transaxles ? Photo's, Engineering Drawings, Specifications, etc ?
JK
Old 03-28-2021, 03:17 PM
tom s tom s is offline
I owned a SD transaxle what do you want to know?The weakest part was the R&P.Bullet proof trans.Tom
Old 03-28-2021, 03:35 PM
I just find the engineering aspect of these units fascinating especially since they made so few. Did you ever have yours apart ? Where did they differ from the regular transaxle and what parts were the same. Do any engineering records or drawings still exist ? Why did they choose to retain the transaxle for the super duty's instead of using the big car rear axle like the racers eventually did ? Did their testing not reveal the inherent weakness of the Corvair style differential ?I'm assuming since you said you "owned one" (past tense) you no longer have it ?
JK
Old 03-28-2021, 05:52 PM
I actually bought it with intentions to use it.Found out after that they dont have a differential.The axles are way bigger,the stub shafts going into the rear end are opposite of a regular 63 V8 car.The inside has a spline shaft that goes straight thru the assm and the stub shaft (female) goes over the steel shaft(making it a spool)The unit consisted of a basic 63 Tempest TQ 2 speed auto.Engineering made a 2 speed planetary system to attach to it to make it a 4 speed manual automatic.What ever gear it was indexed is the gear it stayed in until you moved it up or down.They used a hyd bearing mounted to the rear for the clutch and flywheel.I sold it when I fond it was not going to driveable on the street to Ken Freeman in OK for his real 63 SD tempest. I will post some pics of the assm ASAP.
Until then I will post a link of the genius I bought it from and you can read what he was able to build with one.Enjoy.Tom
Old 03-28-2021, 05:53 PM
http://corvaircenter.com/phorum/read...,454975,455550
Old 03-28-2021, 05:56 PM
This is the better link.
https://www.corvaircorsa.com/V-12-01.html
Old 03-28-2021, 06:01 PM
pics
ID:	563594   Click image for larger version
Old 03-28-2021, 06:02 PM
one more
Old 03-28-2021, 06:08 PM
This was the car and the engine it would have been behind.The engine is a FACTORY all Alu engine that I found at M/Ts back in 1964 and finally got my hands on it a built it.Tom
ID:	563597   Click image for larger version
Old 03-28-2021, 07:28 PM
Thanks Tom...that's a lot to digest. Sounds like you could be a great source for several articles in "Smoke Signals" like the recent Dimitri Toth series. It seems the more information you post here...the more questions I can think of.
Just that all aluminum engine from M/T's shop sounds like a story I'd love to hear more about.
Old 03-28-2021, 07:42 PM
So the stub shafts and axles were fabricated by engineering, but the two-speed
planetary case looks like a commercial unit unless they cast up a special case.
What about the ring and pinion ? Was that custom ? You'd think if they went and beefed up the axles and stubs they would have done something similar with the R&P unless there were space constraints within the differential case. Was a stock differential case used or is that a "one of" too ? Was the torque tube and shaft modified in any way ? Did it connect directly to the crankshaft or did they use a clutch assembly up front too ? Sorry if this is too many questions...like I said, it's just a fascinating piece of engineering
JK
Old 03-28-2021, 07:58 PM
The problem was the deal still used the 7.5 R&P.On the drag cars with slicks they lasted 10-12 passes.The other deal was 3.90 was the lowest avail.I gave the drawings to Ken when I sold him the SD transaxle and Engineering tooled up for what im told was a Xtra for each of the 12 factory cars,not including the 2 mule cars.Tom
Old 03-28-2021, 08:23 PM
The rope shaft bolted directly to the crank just like 326 auto cars.The stick shift stoke cars got a clutch and flywheel up front with a short shaft that was splined to go into the clutch disk and that piece bolted to the rope shaft.The auto car had the TQ converter hanging off the back of the trans axle assm.The SDs as you could see in the pic of mine had the flywheel and starter hanging on the back with the custom made hyd clutch mech.The SD trans axle cars used the clutch to launch and often in the pits as the shift was very violent.I actually got to go for a ride in Jays Corvair.He figured out how to make a differential for the car along with hanging a converter off the back.He even adapted a fan off the back to make the Corvair rear engine air cooled sound.The V12 Jag engine with the twin Buick throttle bodies was another unique deal he did in his own shop.He worked for GM in the early 60s and I believe he owned 4 of the transaxle assm.HMT offered him the Yourtown blue 63 SD tempest mule car for $3000 but Jay already had a 63 tempest with a 421 HO engine in it.Don Keefe did a article of the build up of the alu pontiac engine.I will post the mag and year and month as you might be able to buy one on Ebay.Tom
Old 03-28-2021, 08:29 PM
Alu engine
ID:	563618   Click image for larger version
Old 03-28-2021, 08:32 PM
Sorry,no clue why it sometimes flips pic from my phone.Tom
Old 03-28-2021, 08:34 PM
Here you go!
https://www.ebay.com/itm/HIGH-PERFOR...wAAOSw9RZeKJJk
Old 03-28-2021, 08:36 PM
Doug Doug is offline
Page #40 in this 61-63 forum has a discussion of this car. I posted pages from the June-1963 HOT ROD article about the car.
Old 03-28-2021, 10:37 PM
pont406's Avatar
pont406 pont406 is offline
Roger Rosebush who is building the 63 #50 Lemans replica, has been posting pics and info on Facebook, it's probably 85% done at this point, painted, all fabrication work done, mainly ready for final assembly, its not equipped with a factory SD transaxle,
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
Old 03-29-2021, 01:19 AM
Drag Star Le Mans's Avatar
My thought is the #50 car being a road racer is the trans. wouldn't be subjected to the high launch loads of the drags cars. Maybe this is why is lasted 250 miles?
DragStarLeMans
The Following User Says Thank You to Drag Star Le Mans For This Useful Post:
