Old 03-28-2021, 01:51 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Default Holley Dominator ECU
Anyone have experience with this ECU?
I need a nitrous progressive controller and a data logger for my car, this ECU does that and a whole lot more.
I'm going to stay with a carb and wet nitrous for now, but I can see going MPI and dry nitrous in the future. Traction control is a huge plus too.
My questions are:
Do I need to use a TPS to activate the nitrous? Or can I still use a WOT switch and have the nitrous come on with the release of the transbrake button?
Can I use the ECU ignition control with my current MSD distributor and coil? Or do I have to go with a cam sync and CNP?
www.lancablingsolutions.com
Old 03-28-2021, 08:28 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Check out this guy on YouTube
https://youtube.com/user/boo00st1125
Also, check out Turbo John on YouTube. You can join his pay channel for $5 per month gives you access to his Wednesday night live tech session and he will answer your questions live and show you on the screen.
The Following User Says Thank You to GTO Dan For This Useful Post:
Old 03-29-2021, 01:17 PM
Mean Green's Avatar
Thanks!
Old 03-29-2021, 03:32 PM
JD's Avatar
JD JD is offline
My questions are:
If you are going full EFI then you will already have a TPS to control fueling so using it for nitrous control will be very easy. Would probably harder to figure out how to use a WOT switch. You can have multiple requirements that need to be active before the nitrous will enable. For example you can have nitrous system armed, TPS greater than 85% and transbrake not active. This will activate the nitrous system on the release of the transbrake.
You can use your distributor, coil and I assume MSD box to control timing and retards. If you move to a cam sync and CNP you avoid any possible issues with distributor phasing and can plot a timing curve. This is helpful when you are maximizing your timing with the system on.
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
Old 03-30-2021, 12:48 PM
Mean Green's Avatar
I plan on staying with a carb and wet nitrous for the immediate future. I will switch to MPI and dry nitrous at some point in the future.
After looking into it a little further, I'm going to go with CNP and a cam sync right now.
I know people that know Holley EFI stuff like the back of their hand, but I race against them and multiple cars that they tune.
There is a Holley EFI group on Facebook with a lot of good info. I've been using the search feature and getting a clearer picture of what I need to do.
Old 03-30-2021, 02:00 PM
Scott65's Avatar
Scott65 Scott65 is offline
Consider a crank mounted trigger wheel and a cam sync for greater accuracy.
Old 03-30-2021, 06:13 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I thought the progressive controllers used a time based ramp?
Old 03-30-2021, 07:37 PM
Mean Green's Avatar
I'm going to use my existing MSD crank trigger with a Holley hall effect sensor.
I'm going to call Luhn Performance tomorrow to order a cam sync.
I'm going to use oem D585 coils.
Using the Holley ECU and going CNP seemed complicated at first, but after a few hours of searching the net, it seems a little more straightforward now.
Old 03-30-2021, 07:41 PM
Mean Green's Avatar
The Leash progressive controller I have in my other car is a time based ramp.
I assume the Holley is as well. Everything I've read about the Holley controller has been positive.
Old 03-30-2021, 07:43 PM
Scott65's Avatar
I don't use Holley, but I found it pretty straightforward. The timing is rock steady with the 36-1 crank wheel. You'll like the versatility.
The Following User Says Thank You to Scott65 For This Useful Post:
Old 03-30-2021, 08:06 PM
Scott65's Avatar
Lots of control options with an ecu. Safeties too.
Not Holley, just an example.
Old 03-30-2021, 08:36 PM
JD's Avatar
JD JD is offline
I run CNP with a carb using the Haltech VMS. I use the MSD hall effect crank sensor and the cam sync from LPI. I run a 16volt system and found the stock coils didn't meet the need and moved to the Holley smart coils. I know they are not cheap but definitely much better in my experience on a 16volt system.
I control nitrous and fuel progressive on two separate curves, cylinder to cylinder timing, trans dump valve and log 20 channels. Overall very happy with the system.
I also have a Holley Dominator that I plan to upgrade to and have built the program for that on the bench.
Jim
Old 03-30-2021, 08:51 PM
Scott65's Avatar
Nice! Any plans to also control the fuel/dry nitrous?
Old 03-30-2021, 09:36 PM
Mean Green's Avatar
Thanks for the pic!
Old 03-30-2021, 09:37 PM
JD's Avatar
JD JD is offline
Yes, that is the plan. If you look at the intake you can see where I have the injector bosses covered. We keep getting distracted continuing to optimize the combination.
So far it has gone 4.93 at 143 in the 1/8th with a 1.16 sixty foot time. Car is a little over 3250 with me in it and I am at 1877 lbs/hr on the system. We want to get another 200 lbs/hr through it and the timing curved worked out and we will probably switch over to EFI.
Jim
The Following User Says Thank You to JD For This Useful Post:
Old 03-30-2021, 09:45 PM
Mean Green's Avatar
That's a sweet set up! I plan on mounting my coils just like that, thanks for the pic!
Old 03-31-2021, 01:07 PM
Mean Green's Avatar
Do you see the car picking up ET/MPH with a switch to EFI and dry nitrous?
Old 03-31-2021, 11:20 PM
JD's Avatar
JD JD is offline
Not necessarily but it will allow finer tuning over the fuel side hole to hole which should help optimize the overall tune up. I am also expecting I will run into a point where the engine is getting close full saturation with the nitrous and tuning each hole with EFI should be a little better than changing fuel changes in the nozzle.
I also like the option to run with the throttle body exposed to open through an opening in the hood when I cannot run a forward spacing scoop. May not be too big of a deal but looks cool in my opinion.
Jim
Old 04-01-2021, 06:23 AM
Very NICE, JD!
Old 04-01-2021, 08:18 AM
wreckmastr's Avatar
My questions are:
On my friends carbureted car we use FuelTech for the progressive controller, Timing retards and traction control just as you can with the Holley. A TPS is a must though as it will need to see the TPS to activate and perform other functions. The green in the pic is how he mounted his.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
The Following User Says Thank You to wreckmastr For This Useful Post:
