Old 03-28-2021, 10:24 PM
John O. John O. is offline
Default 68 GTO gas tank
Looking to buy a new gas tank for a 68 Goat. Looking in Ames catalog and its more than a 69 tank. Oversize shipping fee on tanks is $89 plus standard shipping but for some reason a 68 tank is $150 oversize plus standard shipping. You would think they would be pretty similar. Any recommendations for a tank and does anyone know if its thats much different from the other years to warrant outrageous shipping fees.
Old 03-29-2021, 01:51 AM
dataway's Avatar
dataway dataway is offline
Probably has a filler neck already attached, maybe the 69 doesn't ?
Old 03-29-2021, 06:52 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
Here's a thread from a few years back
https://forums.maxperformanceinc.com...d.php?t=770031
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 03-30-2021, 05:02 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
You might want to consider getting a stainless steel gas tank
from Auto City Classic.......I have them in my GTO and my Chevelle and they are fabulous.
Old 03-31-2021, 01:52 AM
dataway's Avatar
How's the filler neck fit for a 68 on the Auto City Classic tanks?
Old 05-18-2021, 02:12 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
FYI - Auto City Classics are not carrying 68 tanks at this time. I ordered online from Advanced Auto - will take original tank to radiator shop to be cleaned, then neck removed/soldered onto new tank.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 05-18-2021, 05:08 PM
vertigto's Avatar
vertigto vertigto is offline
Spectra from either Auto Zone or Advanced Auto. Free ground shipping and 20% off coupon code when ordering online.
Old 05-18-2021, 06:05 PM
dataway's Avatar
BTW ... considering replacing my original 68 tank .... should I remove and keep the filler neck for use on a new tank?
Old 05-19-2021, 08:34 AM
Why have the original tank cleaned if you plan to use a new tank?
I have an original and a repop (made in canada)
Old 05-19-2021, 12:56 PM
Scott Thelander's Avatar
fairly sure 68 necks are 1.5" shorter than a 69
I just put a 69 in a 68 rag top and the gas cap is real close to the plate bracket but the cap doesnt touch
Old 05-19-2021, 02:36 PM
68gtoMN's Avatar
The original tank is leaking badly; therefore, will be replaced. It has gasoline in it now. To remove neck properly without risk of BOOM, I believe that a cleaning will be needed. If not, then I won't.
As others have made mention, the 68 neck is different from 69 - measurably so. As this car was built on the first day of production in Pontiac plant (1967) I'd like to keep the neck and make tank more original. :-)
'70 LeMans Sport
Facebook Event
The Following User Says Thank You to 68gtoMN For This Useful Post:
Old 05-19-2021, 06:56 PM
dataway's Avatar
Still trying to decide if I should replace mine ... outside has considerable surface rust, nothing that looks like it would cause a leak though. Flashlight in the fuel sender hole I see shiny new looking metal ... will have to stick a bore camera in there and look at it better.
Old 05-20-2021, 09:30 AM
I wonder if you could fill it with soapy water to overflowing a couple of times to displace all the gas and more importantly, the fumes?
Sent from my moto g stylus (2021) using Tapatalk
Old 05-20-2021, 11:19 AM
68gtoMN's Avatar
Good idea Greg. I had considered that earlier but had discounted it. I'll look into that when I remove tank.
'70 LeMans Sport
Facebook Event
Old 05-21-2021, 08:33 AM
I'll bet it will work but definitely ask someone smarter than me!...lol
Old 05-21-2021, 03:22 PM
pop the sender out
empty the tank
add dawn dish soap
fill a bit slosh n drain
repeat air dry
sawzall out a 6" + square so you can set the angle when you install
then sweat the tank off the neck
Old 05-22-2021, 02:04 AM
dataway's Avatar
So if I replace my 68 tank I need to keep the original neck?
Old 05-23-2021, 07:53 AM
Half-Inch Stud's Avatar
Hang onto the original neck, at lest until the new tank arrives. Wonder if folks install original necks onto new tanks.
The new neck may have a rear vent pipe that needs removed and plugged. I plugged such pipe and long forgot it is there.
Old 05-24-2021, 09:28 AM
You don't have to replace the neck but the angle of is off on the 69 and it needs to be bent upwards to clear the bumper opening behind the license plate. The 68 neck kicks upwards a bit where the 69 doesn't.
Old 05-24-2021, 02:11 PM
dataway's Avatar
I'm confused Is there a replacement tank for the 68 that has the right neck, or are people using the 69 tank in 68s and tweaking the neck?
Probably the best question is .... what's the best, closest fitting off the shelf 68 GTO replacement out there?
