Throttle return spring for 4500 series ADP carb?
I have a 1250 CFM ADP Holley carburetor. It appears most all normal throttle return spring setups do not work. Does anybody know what setup may work for this?
I just ran a double spring forward to a bracket I made up that attached to the first intake manifold bolt -- or am I missing something?
Great idea and no, you aren’t missing anything...
This is what I had to do to my 1050. I removed the retainer for the 2 springs and installed it under and in front of the throttle bracket cable holder. I then used 2 normal springs for return. Works great. I then make a new gas pedal support bracket out of metal so it would be stronger as the plastic one broke.
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
I went by my old shop at our other house and found one laying in the floor and with about 2 minutes on a grinder fixed it right up!
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
Bracket is made by Allstar and comes with springs, and a Lokar cable, i really like this setup on mine.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
My issue was that an ADP dominator has external secondary opening linkage instead of internal like all other Holley Dominators...
