Old 04-17-2021, 05:34 PM
Mike S's Avatar
Mike S Mike S is offline
Default switched to radials - results
Went out today with the new 315/60 MT ET street radial pros. Switched from Hoosier slicks with tubes that where close to the same size of the 315's. This is a stock suspension car with coil overs in the back and stock shocks on the front. I did move the lower trailing arm 3/4" lower on the rear and loosed the rebound 3 clicks and tighten the comp. 2 clicks. I started at 17 psi hot and left it there all day. Made 6 passes and the 60's where between 1.354 and 1.348. I am happy with that. I am a fan of these tires now.
I ended up loosing in the semi's in 10.0 Index. Bad light and went 9.99.
The Following User Says Thank You to Mike S For This Useful Post:
Old 04-17-2021, 05:55 PM
Dragncar Dragncar is offline
I switched and every aspect was as good or better than bias. Bias tires for many are becoming a thing of the past.
Old 04-17-2021, 06:06 PM
Scott65's Avatar
Scott65 Scott65 is offline
How did it compare to previous?
Old 04-17-2021, 08:49 PM
leeklm's Avatar
leeklm leeklm is offline
Nice to hear, your results were better than mine today! 1st time out this year, track seemed decent, but after making shock adjustments and 3 runs, spun each time with the 26x10 radial. Running 19psi and looks like as the front end runs out of travel, the tire spins 1 or 2 rotations, then hooks again as the front end starts coming back down.
I struggled some last year while switching to the radial, but was able to run off some solid 1.40 launches late in the season. Track was busy today so tough to get runs in... going to try a little more tire psi and continue to tighten the front shocks, and/or put a 28" tire back on, which should help...
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 04-17-2021, 10:06 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What about a radial slick?
Old 04-18-2021, 09:26 AM
Mike S's Avatar
The radials seem more consistent then the slicks when they where new. I have never had 60's that tight in the same day. The old tires where 3 years old and 60's varied from 1.46 to 1.36 thus the reason for new tires.
The handling felt the same as slicks. Did notice any speed increase at all. Mabey because I added radial to the front that are about 12lbs a tire heavier. I did notice the car reacts faster now. What should have .015 lights ended up being .00 lights.
Car weighs 3400 lbs and launch with a transbrake at 3400 rpms. All day the car picked the wheels up 1' and carried them out 30'. We will see what happens in the summer when the track gets hotter.
Old 04-18-2021, 09:31 AM
ponjohn's Avatar
Were your previous slick bias or radial?
Old 04-18-2021, 10:30 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Radials are fast but if the track is sketchy they are junk and most all the tracks we run on are sketchy...they also suck on the street. Having said that a well prepped track and a radial are a thing of beauty...
The Following User Says Thank You to 69Goat1 For This Useful Post:
Old 05-12-2021, 08:45 PM
Mike S's Avatar
Ran a Tuesday night gamblers race last night. Not much track prep and ran with a ton of street cars. So, was not the best prepped track never is on a Tuesday or Friday night.
Tires where great. 1.344, 1.348 and 1.342 60's. Would have been better if I could have won first round. Love these radials. I haven't played with pressure. Set them at 17psi and have been working great so just left it there.
Old 05-13-2021, 10:54 PM
Mike Davis's Avatar
Mike, run them up in pressure. Try 18 or 19. I started at 17 and kept going up. Car 60ft best at 19.5lbs. I have run up to 21 on a good prepped track.
You have to be careful with lower pressures in a radial, the tire will ball up and basically try to run over itself.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
