Old 05-19-2021, 01:24 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Default Rally II wheel colors for modern paint systems, is there a cross?
By now, the original PPG Rally II wheel paint codes have been discussed ad nauseum. My question is, do these codes cross over to any of the modern paint systems and if so, what are they and for which system?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 05-19-2021, 10:01 PM
I restored the original 14x7 JS wheels for my '70 Formula 3 or 4 years ago, and my local auto paint store was able to mix paints to the PPG codes. I actually had them mix single stage urethane in the 2K rattle cans.
I used the following codes:
Argent Silver: PPG Code 8568
Charcoal: PPG/DDL 32947
Grey (Back side): PPG Code 35413
I was very happy with the results.
ID:	566920   Click image for larger version
The Following 2 Users Say Thank You to keith k For This Useful Post:
Old 05-20-2021, 08:28 AM
vertigto's Avatar
vertigto vertigto is offline
Good info Keith..thx.
Old 05-20-2021, 10:15 AM
I used Keith's paint codes when I restored the Rally II wheels on my old 71 Trans Am.
ID:	566936   Click image for larger version
ID:	566937   Click image for larger version
ID:	566938   Click image for larger version
The Following User Says Thank You to eaglesan13 For This Useful Post:
Old 05-21-2021, 09:46 AM
3tas4me's Avatar
I have the codes, problem is the store can’t mix anything off those codes any longer.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 05-21-2021, 06:01 PM
Formulabruce's Avatar
I use DP40LF on the back. Can use a semi gloss 2k clear over it if needed. The epoxy makes it very durable and the clear makes it a rinse off clean.
Old 06-02-2021, 06:39 AM
3tas4me's Avatar
Thanks.
What about the front?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 06-02-2021, 07:55 PM
I use the rally wheel argent for the silver part.
This is like a "which camshaft" question...
Old 06-11-2021, 08:06 PM
3tas4me's Avatar
I was able to get all three colors crossed to the Omni line of paint. The charcoal I had to call PPG and speak with someone in the color library and have the paint store call to get the mixing code. All three were mixed as urethane.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 06-12-2021, 12:09 AM
Norwood's Avatar
Norwood Norwood is offline
Well keep us filled in on the results. Thanks
