WTB 66 Tempest rubber floor covering
I'm looking for a good rubber floor covering to use in my 66 Tempest wagon . My original front one is torn up. If I can't come up with a usable one I'll need to convert to carpeting .I'd like a full set (front & rear )if available . I'd rather keep it stock if possible . I believe that any 66-67 2dr ,4dr or wagon will work . I am doing a black interior . I might be able to dye if another color is found . I will be attending POCI in CT and Pontiac Nationals in Norwalk . Any help in locating one will be appreciated . Thanks , Don
I have a dark red rubber mat from my ‘66 2 dr sedan. It has a couple of holes from a floor shift someone had installed but otherwise good. If you have interest I can post up some pics. May go to POCI for a day so that would work.
LMK. Best to PM me.
" Darksiders Rule "
Thanks for the reply . If it's not too much trouble could you send me a photo or two . Thanks , Don
Don't know how/if they differ but here's a mat from a '67 with a crazy price, but these would fall into the Hen's Teeth category;
https://www.ebay.com/itm/1967-Pontia...-/303570546437
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Dirty but in pretty good shape. Crack at gas pedal area (see third pic) and floor shift holes are really the only issues. I’d sell it for $150. delivered to POCI show.
Rob
" Darksiders Rule "
Hi Rob, Thanks for the photos . I would need to repair them and dye them black . If it's OK with you I would like to give it another week or so before I commit to buying it . I'm still undecided whether to go that route or use carpeting . Sorry for the delay . Thanks Don
No problem but please PM me if you decide you want them as I don’t always check older posts.
" Darksiders Rule "
Sounds good Rob . Thanks , Don
Rubber floor mat
The Following User Says Thank You to Cjkgoat For This Useful Post: | ||
https://www.ebay.com/itm/32318955815...53.m1438.l2649 Maybe not 100% correct, but claim its fitted for 66/67 A body, and its black! picture doesn't represent the actual product application, BTW NOT MY AD ,JUST SHARING THE AD.
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon! |
Thanks for the info . That gives me another possibility . Don
I would like to thank everyone that helped me out . I got what I needed . The search is over . Thanks again . Don
