Is there any easy way of getting this type of wheels cleaned up without scratching Chrome ? very light pits mostly . Thanks for any info ! I have to paint repaint around lug nuts between spokes yet .
Yes. Phosphoric or Oxalic acid..You will be impressed.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Noxon metal polish works well (oxalic based). For heavier oxidation you can couple that with fine bronze wool. YouTube has videos of that combo specifically.
If there’s a ton of rust I usually spray with WD40 first to blast off the bulk oxidation so you’re not grinding it into the chrome with the bronze/noxon. A final polish with Semichrome will usually take it that extra mile and also protect very well. Everybody that does it often has their own routine… lol. That one is just my old standby. |
0000 steel wool will clean up chrome and glass without scratching. Once you've cleaned the chrome, put a good coat of wax on it.
The Following User Says Thank You to nbn For This Useful Post: | ||
I've also just used 0000 steel wool with good results.
X3. Also works on cleaning up old glass believe it or not.
0000 steel wool works but as mentioned some kind of protection is still needed.
Best I've found for a remover and protectant on pitted older chrome is Quik-Glo. Edit - There are three formulas, https://quick-glo.com/?v=76cb0a18730b Frank
![]() ![]() ![]() Last edited by 4zpeed; 07-08-2021 at 04:06 AM. |
