66 Catalina frame serial number
I have a 66 Catalina that I want to check the frame #
Almost all of the frame numbers are unreadable. I have tried using a wire wheel and lightly sanding the rust, not much help Is there some chemical I could use to make the VIN stampings clearer? I know in coins, there is a solution to make the worn away stamped dates re-appear The car has more options than listed in the PHS. Just trying to see if the frame matches the door post VIN Thanks, Ron
Another Red Light Nightmare 1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw 1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project. Semper Fi |
For buffalo nickels there is a product called 'nic-a-date' which makes the dates readable. The date is the highest point on the obverse of the coin and wore off first. It is an acid.
Sincerely, Coin nerd. https://images.pcgs.com/CoinFacts/36236638_large.jpg
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. Last edited by webfoot; 07-27-2021 at 12:05 PM. |
Ron, check with your local police dept auto theft or detective unit. I know that when I was a detective we had an acid that we could lift serial numbers off of guns and stolen car frames even when they had been ground or filed off.
[SIGPIC][/SIGPIC |
Frame serial #
Thanks, I will give them a call.
