Old 07-31-2021, 03:04 PM
gobrdgo gobrdgo is offline
Default 455 oil pump ID.
I have these two oil pumps. The bottom one or the one with the cast four bolt cover is new. I got it in a batch of parts. Can anyone ID it ? The stainless tag says 54.0.
Old 07-31-2021, 03:16 PM
John Milner's Avatar
John Milner John Milner is offline
I believe that is an M54D Melling 60 pound pump.
Old 07-31-2021, 03:46 PM
Thanks. Sounds like we figured it out. So good pump for my 455.
Old 07-31-2021, 04:22 PM
The other pump it also a Melling M54D.
I know that because I bought it new and locked the pickup in place with that 10-32 socket head cap screw using red Loctite.
It worked good for 30k miles on that 455 I sold you and it’s ready for more.
I don’t think Melling even offers the standard 40 psi pump anymore.
Old 07-31-2021, 04:27 PM
Tom Vaught's Avatar
Boost Engineer
It worked good for 30k miles and it’s ready for more.
Agree, I have several M54D"S" oil pumps (60 psi) on the shelf (I just looked) and they are identical to Bart's 10-32 socket head cap screw modded pump.
(minus the Modification) lol.
Tom V.
Old 07-31-2021, 04:52 PM
Cliff R's Avatar
Cliff R Cliff R is offline
As far back as I can remember all the Melling M54 pumps were 60psi. They used to supply them with a lighter spring if you wanted to install it. Not sure what they are selling or supplying now.
The pick-up tube needs drilled/tapped for a machine screw to keep it from falling out. At some point they went to "softer" material for the pick-ups and they will fall out if you don't take extra steps to keep them in place......
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
