Old 08-19-2021, 04:45 PM
Yellow Bird Yellow Bird is offline
Default Carburetor Bolt HELP!
I lost the mounting bolts to my 1977 Rochester Quadrajet carburetor, bolting onto a 77 Pontiac engine. I know there are two lengths. Does anyone know the dimensions, hardness, of these 4 bolts? Were there washers? Any help would be greatly appreciated. Thanks
Old 08-20-2021, 06:06 AM
Aus78Formula Aus78Formula is offline
5/16" - 18 x 1-1/8" long
5/16" - 18 x 3-3/4" long
Old 08-20-2021, 10:03 AM
Sirrotica's Avatar
To add to the above information, no washers on the bolts. Number 2 hardness should be plenty sufficient, although I think GM used 5 hardness, which is overkill. The bolts only need to pull the gasket snug to seal the gasket surfaces, they're not holding the engine in the car. Many people have a tendency to overtighten Q Jet bolts.
Choke up on the wrench handle you use to tighten them because overtightening just deforms the top body of the Q jet. Tighten in a crisscross sequence instead of doing front to rear sequence.
That's all I have to add, hope it helps.....
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-21-2021, 07:51 AM
Hey, Thanks so much for the information. You guys are the best. Respectfully P
The Following User Says Thank You to Yellow Bird For This Useful Post:
