Old 09-01-2021, 06:50 PM
lucky1 lucky1 is offline
Default Fuel pressure.
By the time fuel reaches the carb. , is the pressure the same as it was when it left
a mechanical pump ?
Old 09-01-2021, 07:38 PM
steve25 steve25 is online now
Are you talking about the fuel just reaching the carb , or like in the case of the Q-jet the fuel first passing thru the filter ( hopefully paper) and then into the carb?
Old 09-01-2021, 08:42 PM
Default Fuel pressure after the filter
After the paper filter.
Old 09-02-2021, 06:52 AM
What Carb and what pump are you running, and what fuel pressure is your chosen pump rated at, and also how much ball park HP will this motor be making?
Old 09-02-2021, 09:47 AM
78w72 78w72 is offline
simple answer... yes. the short piece of line from the pump to the carb doesnt loose any or very very little psi. & an unrestricted paper filter shouldnt lower it much if any either.
are you having a fuel psi related issue?
Old 09-02-2021, 10:34 AM
70GS455 70GS455 is offline
Will depend on flow rate. At low flow rates (idle) it should be exactly the same. At high flow rates (WOT) it will be less, and depend on how much restriction.
Sent from my SM-T817V using Tapatalk
Old 09-02-2021, 11:09 AM
Singleton Singleton is offline
Yes, Pascal's Law.
https://en.wikipedia.org/wiki/Pascal%27s_law
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
