72' Bonneville Headers
The car I'm doing some work on is a 72' Bonneville with the 455 engine. I'm installing a set of 6X heads on it that has all the exhaust manifold bolt holes and the customer wants to put headers on it. Does anyone KNOW what headers will fit this car? I would lean toward early Firebird headers but I'm not sure.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
I’m no expert, but the 3 tube headers for a 2nd gen F body, I would think to have a great chance of fitting.
2nd gen F-body car headers will fit fine, use the 4 tubes for better performance.
The HO manifolds will also fit perfectly fine: |
Thanks! I'll go that route.
