Old 09-26-2021, 08:17 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Default 1970 Grand Prix fuel tank
Looking for a good condition 1970 Grand Prix fuel tank.
Let me know what you have. Thanks.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 09-27-2021, 10:33 PM
tri.lllgto tri.lllgto is offline
Same as 69/70 Tempest,LeMans, GTO. Try Jules 520-405-7112 in Tucson if no one
in Phoenix has any
Old 09-27-2021, 11:09 PM
Thanks for the response, but actually there is a difference. The A body tanks will bolt in, but they don't hold the same capacity as original GP tanks. I'm looking for a factory GP tank specifically for the larger capacity.
Eric "Todd" Mitten
Deuteronomy 8:3
Old 10-02-2021, 12:26 PM
gpmodelj70 gpmodelj70 is offline
Default Tank volume
You are correct about tank volume for GP being larger. I had many people tell me they were the same and that the factory literature stating 26 gallon was incorrect. I had to replace my original tank years ago and had to use the GTO replacement 20 gallon tank. I took my original tank and it took 26 gallons to fill with it sitting in the same position as it was on the car .Debate settled…they ARE different. Oh and the filler neck angle and length is slightly different.
Marriage is defined by GOD, not by popular culture!
Old 12-02-2021, 12:00 PM
V-Ped V-Ped is offline
I have one out of a 71 GP. I do not know if there are differences.
70 Goat
74 Ventura
63 Cat
56 GMC
et al.
Old 12-12-2021, 12:58 AM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Just to clarify... '69 & '70 are both 21.5 Gal tanks. '71 & '72 are 26 Gal.
For a '70 built with CA emissions, it has a different tank for EES, but the 49 state tank is the same as '69.
Both style '69 & '70 tanks are reproduced, with one vent pipe for '69 & '70 (without EES) and three vent pipes for EES.
This is information is right from the Pontiac MPC, unless it's wrong?
Grant
Old 01-15-2022, 06:36 PM
GpFreak's Avatar
GpFreak GpFreak is offline
Still looking? I have a decent tank out of a '69 Gp.
Steve Naresky
Old 02-18-2022, 02:03 AM
Grant
Not sure if the MPC is correct or not for commonality 69-70, but I'm looking specifically for a 70 GP with the three vent for EES. It will be a bigger 26 gallon tank for sure as I have one in my 71 GTO currently, so no question as to its capacity. I personally pulled it from a 70 GP. Completely different animal from the 21 gallon A body tanks. I have not seen any reproductions of this correct GP tank.
I'm looking for another one for my 72 LeMans GT.
Thank you GP freak. Sorry for my delay responding. Been offline for a time.
Can you confirm if your tank has the 3 vents for EES and if it's the larger capacity? The filler neck will be much shorter than the 21 gallon tank from the A-bodies (as compared), and it will be a physically larger tank, nearly square in dimension. PM me if so. Thank you.
Eric "Todd" Mitten
Deuteronomy 8:3
Old 02-18-2022, 02:13 AM
Side by side photos. Stock 72 A-body vs. 70 G-Body. Quite different.
Notice both tanks have the three vents for EES.
This is what I'm looking for. Thanks Gents!
ID:	584359   Click image for larger version
Eric "Todd" Mitten
Deuteronomy 8:3
Old 02-19-2022, 05:06 PM
428ho4spd's Avatar
Looking at some photos of different '70 GP's, there looks to have been a change in tank size during the '70 model year production. Here are two survivor cars with their original tanks. The first photo shows the smaller 21.5 gal tank (April '70 build) and the second shows the larger tank (June '70 build) with four indentations in the bottom much like the '71-'72 GP tanks have.
I'm curious, are you still able to access the factory rear strap anchors in the trunk floor when installing these deeper tanks into an A-Body car?
ID:	584517   Click image for larger version
Old 02-21-2022, 02:22 AM
The factory rear strap anchors in the trunk floor get covered by the larger GP tank (the tank dimples fit right over the anchors). When I pulled the GP tank, I also took the longer GP straps.
Once the tank was in the A-body, I had to make mounting provisions for the longer straps by cutting into the cross brace tunnel at the back of the trunk, behind the bumper. The straps kind of land in a 'natural spot,' so it was easy to figure out how to notch and re-anchor the longer straps.
Been holding up solidly for thousands of miles now. Nice to have the extra capacity.
Eric "Todd" Mitten
Deuteronomy 8:3
Old 02-21-2022, 01:22 PM
428ho4spd's Avatar
Obviously the larger tanks were made with those dimples to fit over the existing rear strap anchors rather than requiring redesigned trunk floor braces.
One thing I noticed in the Pontiac MPC is that there's no capacity shown with the '70 EES tank part number. Perhaps it was those cars that only received the 26 gal tanks? I know the '70 GP pictured above with the larger tank was equipped with CA emissions so that fits.
That pretty much sounds like how the '71-'72 GP straps mount.
For sure, nice to have those extra gallons in the tank.
Old 02-22-2022, 06:51 AM
GpFreak's Avatar
Post
Pretty sure my tank is the smaller one without the vents. I did have a '70 from California that had that larger tank with the dimples, it developed leaks in those spots so keep an eye on it.
Steve Naresky
