Old 09-27-2021, 04:57 PM
rememberfireball#22's Avatar
rememberfireball#22 rememberfireball#22 is offline
Default No Start
I am having issue with my 68 GTO. It will start and run as long as you pour gas in carb. First thing I thought was fuel pump, but there is a steady stream of gas coming out of line at carb when cranking. I fell about 18 months ago and broke my hip, so today is first time I tried to start car since I fell. I does not have an internal filter at inlet. I thought maybe an insect nest inside carb, but it has always had an air filter on it. Cliff rebuilt the carb about 6 years ago and it has performed flawlessly. I tried to get on Cliff's forum to see what he thought but I could not .remember my password. Do any of you guys have any ideas? I have not pulled carb yet due to my busted hip , but I am going to try tomorrow. Thanks!
1968 GTO Numbers matching 400 H.O. 4-speed 3:55
1964 T-Bird 46,000 Actual Mile
1928 Model A
2009 Lexus
1981 Dodge D-100
1976 Cadillac Eldorado Convertible
19631/2 Ford Galaxie Fastback
Old 09-27-2021, 05:33 PM
Sounds like the float may be stuck up, preventing fuel entering the carb
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 09-28-2021, 08:51 AM
thanks, that is what I was thinking. Due to my injury about a year ago, I don't think I can remove carb. There is no one in my area that I trust to work on these Quadrajets..I paid Cliff to work his magic, and I don't want someone screwing up his good work. Can this be dealt with with carb still on car? Thanks, Mike
1928 Model A
2009 Lexus
1981 Dodge D-100
Old 09-28-2021, 10:23 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Stuck float/needle and seat
Try tapping with plastic end of screwdriver on side of carb.
Sounds like fuel evaporated and needle is stuck and not
Letting fuel into carb. Also try filling carb thru vent as
Fuel may help dissolve and free up needle or float.
I always put some seafoam down carb vent when she
Goes into storage for winter. Keeps float and needle
Lubed up. Good luck.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
The Following User Says Thank You to 68 Firebird For This Useful Post:
Old 09-28-2021, 02:40 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Gerry
^ Do this! Even if you were to tap it with something less malleable than the plastic end of a screw driver, this is VERY likely the cause.
Fill the fuel bowl via the vent, as mentioned, then tap on top and on the sides of the carb, including around the fuel inlet. It may seem like it's of little value BUT you'd be surprised how even a car sitting for 18 years responds to the same. Good luck with carb AND hip. Don't remove it if you can avoid it. I'm betting on fuel in vent and tapping to solve your issue.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 09-28-2021, 03:51 PM
389 389 is offline
Drain the old gasoline, disconnect the line to the fuel pump from the tank and put it in a bucket. Get your compressor and with the air sprayer wrap a rag around the tip and put it in the gas tank filler. Blow enough air to get the old fuel to come out. Once its empty run a gallon of fresh gasoline through. Then connect it all up put fresh gas in..
