Old 09-30-2021, 12:06 PM
68 BlueBird's Avatar
68 BlueBird 68 BlueBird is offline
Default Head gasket options
After 3 months and 1300 miles, my 535 decided to let a head gasket go. I was using Butlers head gaskets #SPM-19376, which I see they no longer offer. Possibly due to high failure rate? Looks like Butler is offering 2 gaskets for non-o-ring'd blocks now. Cometic and Titan copper. I was just wondering if there are any other options to look into before placing an order. Thanks.
1968 Firebird - IAII 535 - FAST Sportsman - 4L80e - PTC 10" triple disc 3800 stall - Moser 12 bolt 3.55 - Caltracs - Hydraboost
Old 09-30-2021, 02:30 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
I would probably go with the Cometic, along with a light coat of copper spray before installation. We have used the Titan gasket in the past on our drag radial car with a small block chevy and an F2 procharger and had an issue with them trying to seep coolant, wasn't anything bad, but just seepage. We went to the MLS gasket, and never had another problem with that, but we lightly coat them with copper coat....
1978 Trans Am
Pump Gas 461 Stroker
The Following User Says Thank You to TransAm 474 For This Useful Post:
Old 09-30-2021, 02:40 PM
Butler got back to me and they're overnight shipping me .050" Cometic head gaskets and new intake gaskets. This is a real pain in the ass to have to deal with, but Butler is stepping up, as they always have during this entire build. I cannot say enough good things about them. Top notch company to do business with...
The Following 2 Users Say Thank You to 68 BlueBird For This Useful Post:
Old 09-30-2021, 02:43 PM
Thanks for taking the time to make a recommendation. Much appreciated.
The Following User Says Thank You to 68 BlueBird For This Useful Post:
Old 09-30-2021, 02:44 PM
AIR RAM AIR RAM is offline
Give Herb a call at Luhn performance and ask him about their head gaskets. They have their own Cometic 5 layer gaskets made specifically to their specs. From what he was telling me, their head gaskets are superior to the regular cosmetic gaskets for boosted Pontiac applications.
Cant hurt to call and ask for their thoughts...
He convinced me, so I ended up picking up a set for my build.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
The Following User Says Thank You to AIR RAM For This Useful Post:
Old 09-30-2021, 06:18 PM
ErikW's Avatar
ErikW ErikW is offline
Luhn's Cometics are awesome.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 09-30-2021, 09:33 PM
In case anyone's interested, the head gasket failure was due to a bad gasket. There was an obvious defect in this gasket. I should have caught it when building the motor, but didn't. Now I'm paying for it. There's an area of the gasket between the cylinders that wasn't cut/folded over/pressed correctly. It was barely touching the head, as seen in the pic. It finally gave out. I can't believe it lasted as long as it did. These gaskets are crap and obviously why Butler quit selling them. The good news is that all the parts should be here tomorrow, so I should be back up and running Saturday.
ID:	574131   Click image for larger version
Old 09-30-2021, 11:43 PM
Dragncar Dragncar is offline
SPEED SAFE, NICK
Do his head gaskets have the different sized cooling holes for the hot spots ?
