Old 10-02-2021, 07:42 PM
Radman's Avatar
Radman Radman is offline
Default which picture should I use?
Today I had an inspiration. I took the white Tempest to a car show. It has a 61 Bonneville 389 Tri-Power under the hood. A guy looking under the hood said" surprise, surprise, surprise". Now I will be looking for a picture of Gomer Pyle saying that. I want to put it under the hood for a show.
Which of the four pictures should I use?
ID:	574216   Click image for larger version
ID:	574217   Click image for larger version
ID:	574218   Click image for larger version
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 10-02-2021, 07:52 PM
Tom63LeMans's Avatar
Tom63LeMans Tom63LeMans is offline
I like #2. Has the real 60s mechanic look with the hat.
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
The Following User Says Thank You to Tom63LeMans For This Useful Post:
Old 10-04-2021, 01:17 AM
Sanduners's Avatar
Sanduners Sanduners is offline
I agree, #2 is the best one. :O)
