Cast aluminum intake repair With E 85
Hey everybody,
I have a cast aluminum intake that has porting damage for the port divider and wanted to know recommendations and suggestions for repair for use with E 85. I've moved to a rural area and have very limited repair resources so want to know How to do it right. Thanks again, Craig |
Interesting topic hope someone has a definitive answer kind of interested in the answer myself
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
Can you post up a picture?
I would give Masterbond a call and speak to them.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 10-11-2021 at 06:32 AM. |
Splash Zone epoxy. Then cover the repair with some quality clear paint -- spray some into a paper cup and dab with a small touch up brush. Keep in mind uncatalyzed rattle can paint has a long cure time (2+ weeks) without baking. Best to use some 2k catalyzed paint and be sure to cover the edges.
--------------------------------------------------------- Mike B 1968 Firebird Last edited by mback12000; 10-11-2021 at 06:38 AM. |
The expansion and contraction of a Aluminum intake will in time crack off that clear paint and then the epoxy will start to break down.
Got that tip from Darin Morgan, I've used it a number of times and has held up well for me. I think the key is good paint. Of course, welding would be best.
--------------------------------------------------------- Mike B 1968 Firebird |
I used Splash zone epoxy and then sealed off with POR 15 gas tank sealer. The sealer is good to 300 or 400 degrees. I can t remember what the specs were for heat capabilities, been awhile. Granted my setup is strictly race run times but has held up well with E85 over the past 4 years. Also I used it on my Gutsram which made it easy to flow it through the intake.
Craig, What part of iowa are you in???
THere's a few folks in the state that can do what you need done!!!
My experience has been welding is best for a permanent repair. I like splash zone, "Zspar specifically", but as mentioned, it must be sealed with something if running alcohol fuel. also the bonding surface needs to be left rough for best adhesion. If the alcohol fuel can wick it's way between the aluminum and the Zspar, it will swell slightly and begin to break off. Sealing is the key.
Mark Sullens recommended welding
A very Strange land - Fairfield Iowa |
Sorry no pictures
Modifying an open plenum single plane manifold with short runners - by accident - narrowed the divider between the #5 and #7 to a knife edge "1 long |
If you can get a TIG torch in there, that'd be the way to fix it. If ya wanna drive to St. Louis, I can fix it.
im only about an hour away from you & can recommend a couple very good machine shops in my town that im sure can do what you need or refer you to someone that can.
Thank you guys - very generous.
Where in Iowa? Pella? |
Curious what are some of the names of machine shops you can recommend?
Unfortunately, since my accident I won't be able to walk or drive or get into the garage for months. Some curious what is your car - 78w72? Thanks again guys greatly appreciate it, Craig |
will PM you.
i currently own some 2nd gen t/a's i have restored & used the same shop for all my engine work. a 78W72 (obviously). an 81 daytona pace car, & most recently finished a 72 firebird with a 467 stroker with round port E-heads that runs low 11's with a Q-jet & HO intake. i dont post much in the race section since its more of a street car but i have done quite a few test & tunes to see what it can do, still working out some issues to get its best times. Last edited by 78w72; 10-11-2021 at 09:43 PM. |
I'm in waterloo and can fix it i have a micro torch if needed. Jeff
