Old 10-18-2021, 09:50 PM
WARCHIEF400 WARCHIEF400 is offline
Default 1970 GTO PARTS
1970 Ram Air 4 bolt main shortblock std. bore needs bored 30 $4000.00
1970 AM RADIO WORKS $200.00
1968 HURST DUAL GATE SHIFTER RESTORED $525.00
NOS 1970 Wheel well moldings $850.00
1970 pair of used rear wheel molding $200.00
1970 GTO grill $300.00 single
1970 GTO Front Headlight housing assemblies $350.00
1970 GTO intermediate front bumper bracket $300.00
1970 GTO Front bumper center support bracket for horns & hood latch assembly $100.00
1970 GTO lower main duct assembly with vents $200.00
1970 power brake booster and master cylinder with bleeders $125.00
1970 lower main duct and vents $125.00
1970 Intermediate steering shafts $50.00
1970 Rear Windshields $80.00
Coils $25.00
1970 Oil Filter housings $100.00 each
1970 front lower window reveal molding $60.00
1970 rear front upper fender chrome moldings $30.00 pr.
1970 Throttle cable $45.00
1970 Turbo 400 Transmission oil pans $50.00
1970 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00
1970 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00
1970 door vents pr. $20.00
1970 positive battery to starter heat shield tube,
1970 window regulators set of 4 $150.00
1970 brake pedal assembly $125.00
1970 emergency brake pedal and bracket $75.00
1970 rear license plate bracket and holder
1970 water thermostat housings $20.00
1970 door hinges $50.00
1968-72 points distributors $80.00
1970 blower motors $25.00
1970 a/c inner boxes $150.00,
1970 headliner bows $50.00 set
1970 Harmonic balancer $50.00
11 Bolt Timing Cover $110.00
11 Bolt Timing Cover withy divider plate and pump $150.00
1970 Full length windage trays $85.00
1970 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00
NOS A/C Delco PVC $10.00,
NOS PULLEY 481040 still in GM BOX $100.00
NOS A/C Delco oil Filters PF 24 $11.00 each
NOS Three prong Thermo Switch for rally gauges $250.00,
1971 GTO Rear Taillight lenses $150.00 Each
1970 Rear Taillight housings $75.00 Each
1969-72 Goldenrod/Tan wheel crack free $125.00
1969-72 ratchet auto shifters $135.00
Fuel escentrics $35.00
1970 harmonic balancer $50.00,
flexplates $35.00
1970 inside glove box liner $45.00
1970 GTO/LEMANS Rear window Defroster Switch with wiring harness $150.00
assorted stainless moldings,
1970 driver side lower black dash metal trim $100.00
1970 radio rear support bracket $25.00
1970 Tag light & bracket $15.00
Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00
1970 door glass $100.00
used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley,
480509
1970 pillar post covers $45.00
new points and condensers __________________
Timmy Mallory Email me at temallory@msn.com
Timmy Mallory
Old 11-01-2021, 12:58 PM
Mr Dave's Avatar
Mr Dave Mr Dave is offline
I sent you an email about the headlight housing assemblies and automatic ratchet shifter.
70 LeMans Sport
95 Corvette
07 F350 Crew Cab 4x4
Old 11-20-2021, 01:24 PM
Headlight assemblies have all been sold!
Timmy Mallory
Old 01-19-2022, 12:25 PM
jakes1970ta jakes1970ta is offline
Need an A6 Frigidaire AC Compressor and manifold to rebuild. Do you have one? thx
Old 01-25-2022, 07:33 AM
gto66yellow gto66yellow is offline
I need a nice passenger side grill for a 70 gto.
