Old 10-27-2021, 12:11 PM
wooftfd wooftfd is offline
Default 389/421 interchangeability
Going to put a 1964 421 in a 64 GTO I'm restoring. Plan is to remove 389 (original to car), rebuild it, and set it aside. Put the 421 in its place. I only have a bare block and crank for the 421, so can anyone tell me what parts from the 389 can be used? I know about the larger items, heads, intake, but what about dist, alt bracket, ac unit, fan, waterpump, balancer and pullies?
Thanks in advance!!!
Old 10-27-2021, 01:46 PM
Everything will interchange.
Old 10-27-2021, 01:52 PM
77 TRASHCAN's Avatar
Just like in 1964!!!
Shut it off
Shut it off
Old 10-27-2021, 03:57 PM
woohoo!!!!!!!!!
Thank you gentlemen!
Old 10-27-2021, 04:06 PM
Hey B-Man, you ever get your 421 up and running?
Old 10-27-2021, 04:40 PM
Ran perfectly on the test stand.
Not in the car yet, my air-cooled hobby cars have had the bulk of my attention for the past few years.
Old 10-29-2021, 03:59 PM
Old Man Taylor's Avatar
Make sure yours is drilled for a starter in the block. As I understand it '64 was a transition year for the 421 going from a bell housing mounted starter to a block mounted starter.
