Old 12-17-2021, 05:46 PM
washtubman's Avatar
washtubman washtubman is offline
Default 57 Hydramatic Shifting
My Star Chief shifts into 4th gear about 20-25 MPH. Is this normal? If not, how can I make the shifts at greater MPH, other than using the shift lever to manually shift? Thanks for the replies.
Old 12-18-2021, 02:55 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
At light throttle that's a normal 3-4 shift.
Old 12-18-2021, 09:01 AM
Safari Larry's Avatar
Safari Larry Safari Larry is offline
Normal shift speeds are given in the 57 Hydra-Matic Shop Manual (LINK), Section 13, page 111.
Larry Gorden
POCI 1956 Tech Adviser
www.PontiacSafari.com
The Following User Says Thank You to Safari Larry For This Useful Post:
Old 12-18-2021, 05:08 PM
washtubman's Avatar
Thanks, that makes me feel better. Guess I just need to put my foot into it a little more!
Old 12-18-2021, 05:09 PM
washtubman's Avatar
Thanks for the reference; guess I overlooked that!
Old 12-18-2021, 05:35 PM
blueghoast's Avatar
Adjusting your linkage (kickdown) will help longer runout.
Hope this helps.
GT
Old 12-20-2021, 08:35 PM
stevep's Avatar
stevep stevep is offline
They should shift at around 8, 15 & 22 MPH on a light acceleration.
Old 12-20-2021, 09:56 PM
washtubman's Avatar
Hope this helps.
GT
Is that the rod from the carb?
Old 12-21-2021, 08:42 PM
stevep's Avatar
Yes. Shorten it about 1/16" of an inch and try it.
Old 05-11-2022, 09:53 AM
mr67gp mr67gp is offline
Just have to give you a shout out, Larry, for hosting the trove of technical information on your web site for our old sleds. I will need to do something with my '57 Hydramatic to keep it on the road, and the tech manual online is great, and the digital indexing is incredibly helpful.
Thanks.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 05-11-2022, 10:53 AM
Thanks.
Thanks, such appreciation makes it all worth while. It was a 10+ year effort to get everything that is on the site now. I very much appreciate the help, articles and information I got from others on this forum. I use the site often myself. Bill Hanlon was one of the early contributors , he reviewed the Master Parts Catalog before I put it online and has articles on the site.
In retrospect, I probably should have named it differently, pontiacsafari.com makes people think it is about safaris but it is about all 1955-57 Pontiacs and some later years.
Larry Gorden
