If anyone has a spare temperature sending unit for a 1965 GTO without gauges they can sell please let me know. Thanks in advance
I have these 2 but don't remember the year/years. The 1 with the messed up pin head says AC Made in USA 12V. The other just has a 40 on 1 of the flats.
Practicing social distancing for 65+ years |
Bob, thank you for responding. The senders you have pictured are for cars with gauges. I'm not that lucky, my GTO's have the standard equipped warning lights.
here? 8B26 not 64-65 date though.
Do you ha e a part number? I have a few in here
Poncho428, thanks but that is 66 and later.
Ladytata, I don't have a part number but it's a single terminal sender. I'll try and find a part number.
Ok I’ll dig a few out
Sent from my iPhone using Tapatalk |
![]() ![]() Teach me what I’m looking for? Sent from my iPhone using Tapatalk |
![]() ![]() 2554 Sent from my iPhone using Tapatalk |
I'm looking for a single terminal sender. It has a blank side next to the single functional terminal. There's a molded in G and an R on top.
What you have is a 1971 sender. I'm still searching for the correct 1965 number. Thank you for helping.
Ya I ran the part numbers I had, nothing, I have a bunch more but you would need the part number for me to look,
![]() ![]() Looked by group number,anything? Sent from my iPhone using Tapatalk |
Not sure if this helps, ‘83 book probably superseded #’s
![]() Sent from my iPhone using Tapatalk |
If all else fails, I buy stuff here.
Dave that is helpful, thanks
This is the sender I'm looking for.
My '67 GTO also had a temperature sender with the same terminal and insulator shapes like the one in you photo. An AIRTEX 1T1059 matched it perfectly. Check if you have a "50" stamped on the underside.
My '67 also calls for the same switch and when I went to replace it with an NOS unit, I discovered that the number 1993581 shown in the MPC was not the same having two terminals instead of one. I later figured out that the correct switch was 1993582 for the single terminal type like installed at the factory.
Here's both styles currently on eBay... 1993581 / 1993582 Grant |
The '67 Assy Manual indicates 1993582 is the original part number for V8 engines, however, the engine drawing shows the temp sender has two tabs!
FYI, This sender is a 248°F version according to the 61-62 MPC. |
