Old 02-16-2022, 04:03 PM
BcinPhx BcinPhx is offline
Default Trans crossmember problem fit
My 71 was an automatic...put in the 454 and an m22 rock crusher and now can't get the exhaust to clear bottom or top even when flipping or putting over or underneath the frame.
Has anyone found a crossmember with a deep channel which the dual exhaust could fit thru from the bottom? Seems like that's the way I should go.
I really don't want to chop up the exhaust or fabricate a brace to fit.
Thanks,
Bill
Old 02-19-2022, 08:49 AM
Rob B's Avatar
Rob B Rob B is offline
Do you have the right crossmember? The X body and 1st gen F bodies all share the same subframe and there are a couple different ones for different Transmissions. You can even buy the one for a T400 new. I would do a little quick research on which cars Came with your setup and go from there.
ie: big block, 4 spd 69 camaro.
Good luck!
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 04-01-2022, 12:39 AM
I modified it and it works...thanks,
Bill
