Old 02-28-2022, 03:37 PM
Dragncar Dragncar is offline
Default Best bushed solid roller lifter ?
I was wondering your experiences with bushed roller lifters. I know they are not for very high spring pressures and I will not be running them in this engine.
I would imagine Jessel makes the best, if they even make a bushed lifter. But they are very expensive and not needed here.
So is it Isky Red Zone ? Crower ? Other brand ?
Who makes the best one for the money ?
No offset, std bore.
Thanks for any input on this.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 02-28-2022, 06:57 PM
Steve C. Steve C. is offline
Do your homework regarding that subject.
"With proper oil pressure and the correct lubricant, the bushing cannot only last longer, but by spreading the load over a greater area of the axle, the lifter can support higher spring pressures."
https://www.enginelabs.com/engine-te...oller-lifters/
One opinion from the internet....
"Just a note on the EZ roll bushing lifter and longevity; the bronze bushing lifter is not really made for "street" longevity. They are very sensitive to oil contamination and they will wear. They were really designed to withstand extreme rpm and extreme spring pressure in an endurance app, but they are a maintenance item, not a drop in and forget item. You'd honestly be better off with a needle bearing lifter."
https://www.yellowbullet.com/threads...aring.1011354/
Note- I'm not here to specifically recommend a Isky product. It just so happens the comments involved Isky. Personally I used Crower bushed solid roller lifters at one time.
Currently street only, now back to Crower solid roller lifters with needle bearings.
Old information here:
Old 02-28-2022, 07:00 PM
65madgoat's Avatar
These black mamba are perhaps the best solid roller lifter right now from what I hear:
https://www.lgmrnd.com/Black-Mamba-P...p/mrl-6498.htm
Old 02-28-2022, 07:28 PM
PAUL K's Avatar
PAUL K PAUL K is offline
BAM with DLC coating is the best bang for the buck.
Go fast, see Elvis!
Old 02-28-2022, 09:11 PM
JD's Avatar
JD JD is offline
Paul - Do they provide a .903 lifter with the Pontiac tie bar? I assume yes, just asking since their website is limited. Do you know what those would cost?
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
Old 02-28-2022, 11:10 PM
PAUL K's Avatar
Yes they do, I want to say somewhere around $950 with the DLC coated bushing
Go fast, see Elvis!
Old 03-01-2022, 12:10 AM
chuckies76ta's Avatar
Were running the .904 Crower Solid Roller bushed lifters with HIPPO. So far so good. they are pricey.
Old 03-01-2022, 12:27 AM
slowbird's Avatar
slowbird slowbird is offline
If you run a bushed lifter wheel you better make darn sure you have plenty of oil going to them
The Following 2 Users Say Thank You to slowbird For This Useful Post:
Old 03-01-2022, 12:38 AM
mgarblik mgarblik is offline
We had very good luck with Crower bushed lifters in .903 and .937 configuration. Very high spring pressures, 450-480 lbs. closed, just over 1000 lbs open. No failures of roller, bushing, or body.
Old 03-01-2022, 09:28 AM
Hooter's Avatar
Hooter Hooter is offline
A lot of the Dragweek guys are now running the Bam lifters.
67 Bonneville ragtop
The Following 2 Users Say Thank You to Hooter For This Useful Post:
Old 03-01-2022, 09:45 AM
charlie66's Avatar
I use the BAM DLC's . There a real good lifter. They measure dead on ..
I know a vendor that gives really good prices on them .. I found him on Yellow bullet .. BAM doesn't sell to the public .
My Half AN Injun.....
Old 03-01-2022, 12:23 PM
racegto65's Avatar
racegto65 racegto65 is offline
These.
https://iskycams.com/shop/index.php?...ndex&cPath=266
Several people I know run them with no problems. I just bought a set of .937
for my new build
Old 03-01-2022, 01:42 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
When I spoke to Brad, he did not have the .904 lifter, perhaps not in an offset. I went with the BB Mopar lifter with a .210 offset.
To the OP, highly suggest a bushed lifter! Yes, Jesel does make one too.
Dave Polichena
Old 03-01-2022, 02:24 PM
opeliac opeliac is offline
Who is the member on YB?
Old 03-01-2022, 03:05 PM
PAUL K's Avatar
My usual wait time has been about three weeks from BAM.
How did the Mopar lifters work for you?
Go fast, see Elvis!
Old 03-01-2022, 03:25 PM
cgeise's Avatar
cgeise cgeise is offline
I ran both Isky and crower bushed no issues
Old 03-01-2022, 04:14 PM
charlie66's Avatar
you have a pm..
Old 03-01-2022, 10:30 PM
guidos's Avatar
guidos guidos is offline
I run .904 morel bushed, I also have wideport heads so I have an offset as well. Work great for me, no issues and I put a few street miles on in a year!
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017!
Old 03-02-2022, 02:06 AM
krisr's Avatar
krisr krisr is offline
I bought a set of BAM bushed lifters from Kelvin Poe a few years ago now. He ran them for 1 dragweek season from memory and I put them into my street car. No restrictors in the lifter bores or restricted pushrods. Haven't checked the valves in a few years now but everything is still quiet as a mouse so no reason to assume anything has moved. 260lbs on the seat. 580lbs open. After my surgery I might bust off the valve covers and throw some feeler gauges on the valve stems, but it's not a priority to be honest with the way it's running.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 03-02-2022, 07:46 AM
aaronman aaronman is offline
I have run Isky and Crower 842 bushed lifters in all our drag engine combinations with no failures.
