Old 03-20-2022, 06:43 AM
tigergto's Avatar
tigergto tigergto is offline
Default Oldsmobile Silhouette
I bought a 2000 Shiloutte to keep at my winter home In Florida. The van is in terrific condition. Problem is the headlights. The lighting wasn’t up to par, so I installed new headlamp assemblies and the brightest Halogen bulbs I could buy. I had the lamp assembly adjusted by a mechanic, still I’m not satisfied. Is there anything else I can do?
I do belong to an Oldsmobile forum but it doesn’t get much action. I will post this question on that forum also.
Old 03-20-2022, 11:26 AM
Jim Scites's Avatar
Jim Scites Jim Scites is offline
https://www.carid.com/2000-oldsmobil...adlight-bulbs/
Lots of choices there, not sure what you are looking for.
Go Fast... Return... Go Fast Again... Who cares about left turns???
Old 03-20-2022, 11:55 AM
tigergto's Avatar
Thanks Jim. I’ll look into the LED conversion kit. More than I would like to spend, since I’ve already spent quite a bit chasing the problem. But if i can be sure it works I’ll go for it. Have you any experience with the kit? Is it plug and play?
Old 03-20-2022, 01:49 PM
Make sure the bulbs have a solid, clean ground. If possible run to battery ground on block.
